Dsd to pcm
  • Saitenschwinger
    • Oct 2021
    • 13
    Re: Dsd to pcm
    Sorry, but I think we are still talking about two different things. Peak normalization is not only for simply changing the volume, it is for maximizing the peak level to the maximum peak level directly in the file. This has nothing to do with replay gain or the EBU128-Level.
    Peak Normalization makes sense. That´s the reason, Your dBpoweramp has a peak volume normalize PlugIn, but only track-based, not album- or folder-based.
    Is that a lot of effort to add this feature? It would save work immensely and is for me the decision whether dBpoweramp or AuI Converter. dBpoweramp is much more sympathetic to me because of a lot of reasons, but without the feature the effort of file processing is too great, because the batch processing in AuI-Converter is fully automatic. And I have a lot of dsf-files to convert.
      • 1749
      Re: Dsd to pcm
      Hey Saitenschwinger,
      I still don't get it.
      So it's like replay gain (apply)?
      • Partha
        • Nov 2017
        • 158
        Re: Dsd to pcm
        Reprising an old thread. If I am converting FLAC to DSD and wish to volume normalize, do I need to set the bit depth at 32 bit floating point first up or just the volume normalize DSP?
          • 43974
          Re: Dsd to pcm
          You could do.
