Using the Multi Encoder and How to Make 2 folders - 1 For Each Codec?
  • Techybec
    • Jan 2021
    • 9
    When ripping using the 'multi encoder', MP3, and FLAC codecs, is there a way to make a folder for the FLAC files and then a separate folder for MP3? - At the moment they're both going into one folder.
    • 1750
    Re: Using the Multi Encoder and How to Make 2 folders - 1 For Each Codec?
    You have to configure the path within the encoder itself. So you can configure different paths for the encoders.
    • Techybec
      • Jan 2021
      • 9
      Hi. Yeah, I tried to do that but it would only allow one folder for the album - regardless of what codec.
        • 1750
        If you add two or more encoders to multi encoder, then you can configure one path for each encoder.
        • Techybec
          • Jan 2021
          • 9
          I tried, but it keeps putting them in the same folder!??
          I wonder if this has anything to do with using the free trial??
            • 43989
            On each encoder page within Multi-Encoder, is the 'Output To' section, here is where it is set to write to based on Naming, each encoder can have its own output location.
