Bit depth DSP - 32-bit float?
  • GHENDER3
    • Jan 2021
    I have just downloaded the current trial version of Music Converter, Mac OS, v 17.3. I am attempting to duplicate a workflow in which the first step is using the bit depth DSP to convert the source to 32-bit float. However, I don't see 32-bit float offered as an option. I see fixed bit depth, and minimum and maximum bit depth. I attempted to set minimum to 24-bit and maximum to 32-bit, and I got a 24-bit WAV. I can force it to create a 32-bit float version of the audio by skipping using any DSPs and have DMC output the file as 32-bit IEEE float. And I suppose I could then take that file and do the rest of steps in the workflow (mix to stereo, normalize, bit depth to 16-bit with dither).
    But the DSP effects guide for the bit depth DSP makes it sound like 32-bit float is an option. If so, where is it?
    Thanks for looking
    Super Moderator
    • 1535
    Re: Bit depth DSP - 32-bit float?
    Fixed in new beta version, thanks for reporting.
    This is a major refresh of the R17 series, addressing some usability issues with R17 features, Multi Encoder in particular. Current version: beta 5 Download: https://www.dbpoweramp.com/beta/DMC-R174b5.dmg Changes since R17.3: Added multi-checkbox selection in Batch Converter filters dialog. Changes in beta 2: Fixed a
