Rel 17: No preview sound?
  • marcosax
    • Jan 2019
    • 10
    iMac running Catalina 10.15.5 here.
    I upgraded from Rel. 16 to 17 a month ago but never got to use it until now.
    Wanted to start ripping a bunch of CDs to add to my libraby, but I found out I can't preview tracks.
    CDs spin up, but counter is stuck to 0 and I get no sound.
    Tried beta 9 with same result.
    Tried running previous Rel. 16.8 and works just fine.
    Please advise.
    Also, please confirm the following is true: ripping a CD to DSD gives no sound enhancements over FLAC
    TIA
    • 5744
    Re: Rel 17: No preview sound?
    Correct, a CD is a 16/44.1 file. ripping it to DSD creates a larger file container, but does not magically turn a 16/44.1 CD file into a DSD file from an audio content point of view. You just have larger files for no reason. Best to rip the CD to regular FLAC.
    • marcosax
      • Jan 2019
      • 10
      thank you garym for confirming that.
      Any hints on the other issue of DBPoweramp 17 not preview-playing CDs?
      16.8 works fine. I checked Security & Privacy Pref Pane and only 16.8 shows up, even if I try to add 17 (actually, Files and Folders doesn't give access to add any application, they are already there and only 16.8 is listed)
        • 5744
        Sorry, no. I never use the preview playing option and I'm not at home to test. I use windows version in any case. I do read that there are all sorts of security/permissions issues with Catalina OSX.
        • marcosax
          • Jan 2019
          • 10
          thank you anyway.
          Beta 17.9 rips ok as in 16.8, anyway. I was just wondering if the issue of not previewing was a symptom of other glitches not as well apparent.
          waiting for a hint from others (Spoon?)
          TIA
