The rip speed cannot be set with MacOS_R16.6.
  • Eule27
    • Oct 2019
    • 8
    The setting field is gray (not active) and without the blue setting button on the right side.
    I bought the version for Mac OS. Before I had version R15.3 and it still runs perfectly on Windows 10 (Parallels Desktop).
    There I can adjust the rip speed depending on the drive type.
    The Plextor-CD-R PX-W1210 allows me under R15.3 the speeds x1, x4, x8, x24, x32.
    The Yamaha-CRW_F1E allows me under R15.3 the speeds x10 and x24.
    Both drives run under MacOS_R16.6 (1) only at maximum speed.
    Have I bought the Mac version forever and should I continue ripping with Windows 10 and R15.3?
    What should I do?
    • 45141
    Re: The rip speed cannot be set with MacOS_R16.6.
    It is different interfaces, parallels allow a low level scsi access to the drive, we can issue ATAPI commands direct to the drive.
    OS X we have to go through apples own defined calls, which are not as extensive.
      Super Moderator
      • 1527
      This is addressed in the latest beta version-
      Current version: 16.7 beta 3 Download: https://www.dbpoweramp.com/beta/DMC-R16.7b3.dmg Changes since R16.6 Fixed CD Ripper inaccurate status sometimes not showing in red color. Added extended CDDA debug logging to investigate specific reported bugs. Changes in beta 2 Added attempted fix for missing [origfilename] in file
      • Eule27
        • Oct 2019
        • 8
        Thank you,
        with this program version the setting of the ripping speed works.
        Juergen
