SACD to flac
  • bkTerry
    • Mar 2019
    • 8
    SACD to flac
    Hi, I am trying to convert some sacd iso files to flac and have used 'iso2dsd' which has given me some .dff files. I downloaded and setup the db codec dsd-sacd for my db poweramp. When I try to use the db converter it fails with a message "DSD in not uncompressed, cannot decode". This moves it beyond my understanding, so would appreciate some detailed help in newbie language on how to have it all happen please. e.g. do I need to add an umcompression activity prior to using db converter? If so, suggestions would be great.
    Thanks, Terry
    • 43929
    Re: SACD to flac
    Use the option convert 'DST to DSD' when using iso2dsd, sacd can contain compressed audio in the DST format.
    • bkTerry
      • Mar 2019
      • 8
      Re: SACD to flac
      Brilliant. Thank you.
