Wrong sorting?
  • pavaroo
    • Jan 2020
    Wrong sorting?
    Hello together,
    I'm new in using this interesting product and I don't find the right sorting in the setting 'Folders & Filename Browsing{_no_track_list_}'
    I enabled the option 'Multi Disc Albums show as [disc] [track] [title]'
    The Tags are set correctly (albumname, disc no, track no, etc.), but the songs are still sorted by filename.
    What am I doing wrong?
  • Mike-B
    • Aug 2018
    • 207
    Re: Wrong sorting?
    I've always believed File & Folder Browsing is simply looking at your NAS music folders & sub-folders that are auto-sorted in alphabetical order.
    I don't think any of the Config setting change it from just that basic view
    I have been around all various config options & these are in the various Artist & Albums browsing
      • 45170
      Re: Wrong sorting?
      Folder and filename browsing does not use any ID tags, only the filenames.
      • pavaroo
        • Jan 2020
        Re: Wrong sorting?
        A shame, because this sorting is essential for me.
          Re: Wrong sorting?
          Then don't use Folders & Filename Browsing.
          You stated The Tags are set correctly, so you can use the other default browsing views in Asset, or you can customize the Browse tree to fit your requirements.
          • Mike-B
            • Aug 2018
            • 207
            Re: Wrong sorting?
            I used Folders & Filename Browsing with another brand software & was happy, until I found Asset & what more can be done.
            Get used to it, take the time to learn what it can do, it is an eye opener
