Results 1 to 4 of 4
Thread: converting issue
  1. #1
    Join Date
    Nov 2014
    converting issue
    Hi Guys
    need your help
    So i am trying to convert a folder of FLAC files, as it processes each one they should appear as MP3 files
    But in the last couple of days this has not happened, i dont know if i have accidentally hit a switch or something
    Any help i would be grateful
    cheers
  2. #2
    Join Date
    May 2014
    Location
    England
    Re: converting issue
    Quote Originally Posted by gallorgs View Post
    Hi Guys
    need your help
    cheers
    A bit more info would help. For example, what and where is your output set to? Any DSP effects?
  3. #3
    Join Date
    Nov 2014
    Hi Timster
    the output is set to music\source filename & there is no DSP effects
    cheers
  4. #4
    Join Date
    Dec 2008
    Location
    London, UK
    Can you tell us what has happened? What steps do you take and at what point do you have an issue and/or error message? What is the error message, if any? Which platform/version are you using?
Posting Permissions
  • You may not post replies
  • You may not edit your posts
