AIFF to FLAC conversion does not include all metadata
  • lucasvickers
    • Apr 2019
    Hello,
    I'm converting an AIFF to FLAC. Most of the metadata gets correctly transferred, but certain pieces are not.
    Missing metadata:
    • Grouping
    • BPM
    • Remixer
    • Release Time
    • Official Audio File Webpage
    • Publishers' Official Webpage
    Things that are correctly copied:
    • Title
    • Artist
    • Album
    • Year
    • Track
    • Album Art
    Any idea what may be causing this and what can be done? I did some Googling and I don't think there are any DSP processors that can address this.
    Lucas
    • 43965
    Re: AIFF to FLAC conversion does not include all metadata
    right click on the original aiff file >> Edit ID Tags, are all the tags listed by dBpoweramp?
    do the same no the FLAC file.
    • lucasvickers
      • Apr 2019
      Thanks for that -- getting closer. I was using Yate to view the tags which is giving a slightly different result.
      Within dBpoweramp, it's showing identical tags.
      Within Yate, I found the missing tags defined under the "User Defined Tags" section.
      Any idea why this is? I wonder if readers will have issue if tags get moved to the User Defined Tags section?
        • 43965
        You would have to ask Yate, the tags are written with a simple element name, so 'BPM' will be stored as 'BPM'. It sounds like yate only expects certain tags in FLAC and all others are 'user defined'
        • lucasvickers
          • Apr 2019
          Got it -- thanks!
