Cover Art
  • RWI
    • Mar 2019
    Cover Art
    Hi I have downloaded and trying out Music/Batch converter for Mac. I have a music collection ripped from cd's through iTunes in Apple lossless format. After conversion to Flac I lose the cover art. I have verified the files have art by getting info on the actual files though the finder and also installed a script in iTunes that verified the artwork is embedded. I have spent a good amount of time trying to figure this out and I seem to be stuck, what am I missing? Thanks for any help!
    RWI
    • 43929
    Re: Cover Art
    See if dBpoweramp can see the art, right click on a Apple Lossless file >> Services >> Edit Tags with dBpoweramp
    is any art shown?
    • RWI
      • Mar 2019
      Re: Cover Art
Name:	Screen Shot 2019-08-20 at 7.52.50 PM.jpg
      Hi, life got in the way for a while and I am finally ready to get back to this. When I view the original file in the finder you see the album art in the preview image, after conversion you do not. The embedded art does transfer properly. How can I make the preview image also be brought over to the converted file?
        • 43929
        Re: Cover Art
        Apple would not show cover art in FLAC files because it cannot read them, you would have to use dBpoweramp Edit ID Tags to see if there is art in the FLAC files.
        • RWI
          • Mar 2019
          Re: Cover Art
          Hi, cover art shows to be embedded if I view in tag editor but still does not show up in a the finder view. Is there anyway to correct this or are you saying on a Mac this is normal?
            • 4015
            Re: Cover Art
            No, you cannot correct this in the Finder. As Spoon said earlier, Apple does not read flac files and Finder is part of Apple's operating system.
            • RWI
              • Mar 2019
              Re: Cover Art
Name:	Screen Shot 2019-08-22 at 5.33.02 AM.jpg
              Here is the same Flac file shown before, I copied and pasted the image into a finder get info window so it seems that it can be done. Perhaps I do not fully understand when you say Apple cannot read Flac files. iTunes cannot read Flac for sure, however they appear normal in the finder and do play in Quicktime player.
                • 1748
                Re: Cover Art
                Finder is part of Apple's operating system, which can't handle (play or display album art) flac files. The operating system doesn't know anything special about those files - not that these are audio files or that there might exist embedded album arts. To play those flac files you use Quicktime, which is an add on promgram, but not an integral part of the operating system.
                  • 4015
                  Re: Cover Art
                  Please confirm the following:
                  1. You see embedded artwork in the apple lossless files, when using dBpoweramp Edit ID-Tag?
                  2. You do not see a .jpg file in the flac folder, after conversion to flac?
                  3. You do not see embedded artwork in the flac file when using dBpoweramp Edit ID-Tag, after conversion to flac?
