Accelerated Audio on MPG->WAV
  • Teq
    I have searched the forum and couldn't find a similar post, so...
    I have a MPG file that is 2 minutes, 33.487 seconds long, using Layer-2 compression on 44.1KHz stereo audio. When I convert it to WAV (also 44.1KHz stereo), it comes out 1 minute, 53.476 seconds long. All of the audio is there, but it is sped up (almost exactly 4:3). The original MPG file plays fine in Media Player, Goldwave, etc., and Goldwave converts it fine. But I would really, really rather do this in the future with dbPowerAmp.
    Anybody got any ideas? If any of the moderators would like to see the file, I can upload it.
    Thanks all for any help in this matter.
    -Teq
    • 43929
    It is the mpg decoder I am using, not so great for films. Visit codec central and install the mp3PRO codec, it should help (besure to follow the installation instructions to the letter)
    • Teq
      Thanks!
      Thanks, Spoon! I will give that a shot asap.
      -Ken
      • Teq
        Does the MP3PRO thing require WinAMP to run? I don't have WinAMP installed (and don't want to install it, if I can avoid it), and so I had to trick the MP3PRO installer into giving me the DLL. Once I got the DLL, I put it in the dBpowerAMP directory and deleted MP3.dll as the instructions described. I then attempted to use dMC, and it crashed with an access violation every time I tried to convert an MPG file. I think I followed the instructions to a T, did I miss something? Or does it actually require WinAMP to run?
        Thank you so much for your help!
        -Teq
          • 43929
          I think you put it in the wrong directory (move it to the folder listed below) - install the mp3PRO driver from codec central, then put the winamp DLL into the folder it has created - dbpoweramp\multiplayer\input\mp3pro
          • Teq
            I think I got that part right. Here is my dir structure:
            dBpowerAMP\
            ....Multiplayer\
            ........Input\
            ............cda.dll
            ............in_mp3PRO\
            ................in_mp3PRO.dll
            ................Place Winamp in_mp3PRO DLL in This Folder.txt
            ............mp3PRO.dll
            ............Wave.dll
            ............WMA.dll
            The original MP3.dll has been deleted, and the in_mp3PRO.dll has been placed in the appropriate directory. Did I miss something that I was supposed to do? Any other ideas?
            -Teq
              • 43929
              Yes that looks right, if you run the dMC Configuration program, does it list the mp3PRO input codec, or does it crash also?
              • Teq
                dMC Configuration runs fine, and lists the "mp3PRO Input Decoder" along with a long string of mpg-related file extensions.
                Thanks for the continuing assistance!
                BTW - I can be reached at kgriggs@fast-talk.nospam.com or as 'FizpaWiz' on AIM if you'd prefer a higher-bandwidth conversation.
                -Ken
                • Teq
                  Spoon? You still there? I am still looking for a way to resolve my crashing problem with mp3PRO. Any ideas?
                  BTW, I know it is obvious, but remember to remove the "nospam" from the e-mail address in my previous post if you'd like to contact me directly.
                  Thank you!
                  -Teq
                    • 43929
                    I am out of ideas, are you able to try it on another machine?
