Fail Converting .MP3 to . WMA
  • Rokitman
    • Jan 2013
    Using DBP 16.2. (64 Bit)
    Trying to do a batch conversion of mp3's to wma's. Keep getting an "Unable To load Decoder" error. The Encoding drop-down box shows both .mp3 (Lame) and Windows Media Audio 10 in the list. But every conversion attempt fails.
    Also, when I try to point DBP to the folder holding these files, nothing shows up in the list and it says No Audio Files Have Been selected. This happens whether trying to convert one file or a batch. The only way for the files to be visible is if I right click ~ Convert To using Windows Explorer.
    • 43927
    Re: Fail Converting .MP3 to . WMA
    It suggests that something is blocking the mp3.dll from loading, you have any security software?
    Also try to update to the latest version, R16.5 is out now.
