Using dither when upsampling?
  • Nubben
    • Apr 2008
    • 154
    Hi all,
    I probably have not grasped the concept of dither but if I am upsampling a file from 16bit/44.1khz to 24bit/96khz should I be using any other DSP effect than the upsampling/bitdepth options?
    Many thanks!
    Nubben
    • 4015
    Re: Using dither when upsampling?
    Why bother to upsample 16-bit/44.1KHz files?
    • Nubben
      • Apr 2008
      • 154
      For the sake of argument?
        • 4015
        Sorry, I don't understand what you mean.
        • Nubben
          • Apr 2008
          • 154
          If you disregard any reason whatsoever why someone would upsample a 16/44.1 file to 24/96, should I use dither? I have read that one should use dither when downsampling from say 32bit to 16bit. I just would like to know.
            • 1749
            Digital upsampling gives you no more information, but only more signal. In other words: it is the same audio quality but with a bigger file size.
              • 4015
              It is a time consuming process, you gain nothing and lose disk space, so I was simply interested in why you would want to upsample a 16-bit/44.1KHz file.
              In dBpoweramp, Triangular dither is the recommended/preferred option.
              • Nubben
                • Apr 2008
                • 154
                Thanks @mville. I just wanted to understand why dither is needed when downsampling and not upsampling.
                • Nubben
                  • Apr 2008
                  • 154
                  Thanks Dat Ei
