Not running
  • Gye
    • Aug 2018
    Not running
    Hello I purchased asset a few weeks ago and two weeks ago it just stopped running. Restarting both Windows 10 computer and Asset pnp has not changed this status, Any help appreciated Gye
    • 4015
    Re: Not running
    Has Windows 10 performed any Windows Updates in the past two weeks? Which version of Asset UPnP are you using?
    What is Asset Running Mode set to, in Asset UPnP Configuration?
    In the Task manager >> Start-up tab, is there an instance of Asset-UPnP and is it enabled?
    In the Task Manager >> Details tab, are there any instances of Asset-uPNP.exe?
      • 43985
      Re: Not running
      It is possibly easier to simple reinstall Asset, this will ensure it has not been removed by a Windows update.
      • Gye
        • Aug 2018
        Re: Not running
        A hearty thanks to both of you. I didn't want to reinstall as i couldn't find the registration details, but it worked well, thanks for taking time to reply, Gye
        • Spyda
          • Dec 2015
          Re: Not running
          Hi mville, I am having the same problem with Asset closing down, but pretty well every night. Would appreciate some help.
          Answers to the above questions are:
          - Windows 10 is set to auto update, however this won't happen every night
          - Local Account
          - Yes
          - Yes, presently 2
          p.s. running version 6.1 of Asset uPnP
          Many thanks
          Kevin
            • 4015
            Re: Not running
            What makes you think Asset UPnP is closing down every night i.e. exactly what symptoms do you experience, that lead you to believe this?
            • Spyda
              • Dec 2015
              Re: Not running
              My Cyrus sudio streamer says, "Cannot browse server."
              When I open Asset on my PC it is in state `Not Running'.
              Clicking RESTART reactivates Asset and my Cyrus then can browse and play.
              p.s. not quite every night, e.g. this morning it was still running
                • 43985
                Re: Not running
                Switch Asset to the other running mode (service).
                • Spyda
                  • Dec 2015
                  Re: Not running
                  Thanks Spoon, have made that change - will see how it goes for a week and will let you know.
                  Really appreciate the fast and capable responses via the Forum
                  Cheers, Kevin
