Right-click options now showing...
  • nyrwolf
    • Nov 2017
    "Convert to" and "Edit ID tags" are now showing up in the right-click menu in Windows 10. "Batch-convert" does show up in the right click options. Is there a fix for this?
    • 1749
    Re: Right-click options now showing...
    Now showing or not showing?
    • nyrwolf
      • Nov 2017
      Not*
      My bad
      • nyrwolf
        • Nov 2017
        Re: Right-click options not showing...
        Let me try this again....
        "Convert to" and "Edit ID tags" are not showing up in the right-click menu in Windows 10. "Batch-convert" does show up in the right click options. Is there a fix for this?
          • 43985
          Reinstall dBpoweramp. If another program changes the association for the audio type (ie a new program takes over playback) you have to reinstall dBpoweramp to put the convert to back.
          • thexfile
            • Jul 2010
            • 177
            Sounds like User Account Control setting?
