Tags, Tags, and more Tags ...
  • monsterjazzlick
    • 1764
    1. I Mean Madonna cd after ripping and again after running convert to process embedding art.
    I have converted Madonna from folder to embedded art. I followed the same steps/settings as I did earlier.
    Before, the folder art-file disappeared after the conversion. But this time (I tried it twice actually) the folder remains, and so I assume the album now has both folder AND embedded? See what you think:
    • monsterjazzlick
      • 1764
      Dont know if they change. That&*8217;s what these tests are trying to figure out. That is, at what point do these extra tags get added. I&*8217;d want to see prerip, postrip, and post running batch conversion.
      Cheers. My only guess is that something may have been set incorrectly and somewhere along the way, over the past weekend, we have managed to get it corrected - inadvertently or not!
      My head is pretty mashed with it; so must yours be!
      I can't really complete my final 50 or so Classicals until I know this has been fixed. Classsicals are stressful enough without additional neg. factors.
        • 5747
        Ok. So no change tags post rip and post conversion, so everything works fine now?
        • monsterjazzlick
          • 1764
          I think I have taken about 15 screengrabs tonight! lol That's got to be my record to date!
          • monsterjazzlick
            • 1764
            Bizarre!
            Yes, seems to be OK I think?
            In the screenshot of '631', does this indicate to you that the Madonna CD has both folder and embedded art, please?
            • monsterjazzlick
              • 1764
              garym,
              I have PM'd you.
              Paul
                • 4015
                You can answer this yourself.
                1. Does the folder contain any .jpg files, named folder or cover?, If yes, then you have the folder artwork.
                2. When you select Edit ID-Tag, does the artwork appear in the Album Art section, at the bottom of Edit ID-Tag window?, If yes, then the file(s) have embedded artwork.
                • monsterjazzlick
                  • 1764
                  Hi mville,
                  It now seems that whenever I try and use 'Batch Converter' to change folder art to embedded, it does create an embedded version BUT the folder art remains in place! I have just tested it about 10 times now, and same results for all. I assumed it was converting everything correctly, but now, having tried it multiple times, the folder art is not being removed (ie. so I have TWO artwork 'versions' per CD!). This is what has been throwing me all along. However, I am still holding my hand up in case their is a mis-configured setting on MY part.
                  Cheers.
                    • 43930
                    The embedding of art (via Update ID Tag) would not delete folder.jpg, if you wish to remove all those you can open a Windows explorer window, browse to the root of all your music and in the search section on the right type:
                    There will be a large list of found files, you can select them all and delete them to recycle bin.
                      • 5747
                      I might keep them both anyhow. Doesnt hurt anything.
                      • monsterjazzlick
                        • 1764
                        Thanks Spoon. I'll have a look tomorrow ...
                        • monsterjazzlick
                          • 1764
                          Do we trust Windoze in terms of 'reliability'?!
                            • 5747
                            Yes
                            • monsterjazzlick
                              • 1764
                              yes
                              ok.
                                • 4015
                                Why assume the ID Tag Update utility codec would remove artwork OR that you can only have one or the other, i.e. what if you wanted both folder artwork and embedded artwork?
