Tags, Tags, and more Tags ...
  • monsterjazzlick
    • 1764
    I am ripping the 'Hooked On Classics' CD:
    Regarding the track-listing, as per above link (and on the rear of the CD case), each title is that which is designed to encompass material comprising a 'medley':
    Hooked On Baroque
    Viva Vivaldi
    But, in the CD liner-notes, it can be seen that each of the above examples contains (say) 6-10 different pieces!
    Would you just use the titles as per above (ie. as per CD rear). Otherwise, one is going to generate massively elongated track-title fields!:
    Hooked On Baroque: Prelude No.1; Prelude No.7; Fugue No.8; Fugue No.12; Sonata No.3; Sonata No.9; Concerto No.2; Concerto No.4; Suite No.7; Suite No.8; ...
    Many thanks.
    • Jailhouse
      • Sep 2016
      • 388
      I'd go with the titles as given. Trying to list all the pieces is too much work for what appears to me to be a lightweight, easy-listening release.
      • monsterjazzlick
        • 1764
        Cheers JH; I will go along with that then.
        However, the first two tracks are 'medleys'; and so contain snippets of works by multiple composers:
        "A Night At The Opera"
        "Hooked On Classics Parts 1 & 2"
        Composer-wise, for the same reasons as my previous post, it would be cumbersome to include all 8-12 of the aforementioned:
        "A Night At The Opera": Handel; Gilbert & Sullivan; Beethoven; Vivaldi; Bizet; Wagner; Rossini; Mozart; ...
        Paul
        • monsterjazzlick
          • 1764
          ... btw - I am go to list the 'Hooked On Classics' CD under 'compilations'.
          • monsterjazzlick
            • 1764
            I am ripping a Haydn CD: Symphonies Nos 92 & 103, on the label Basic (Classics) - TRA045. I am damned f I can find any info on it! The liner notes are pretty sparse, to say the least.
            I would be grateful if anyone could interpret, please, the name of the orchestra (in English):
            Estnisches Symphony Orchester
            The result I get is for an Estonion orchestra:
            However, I don't think this is correct.
            The second orchestra on the same CD is:
            Staatliches Kammerorchester Zilina
            Same question applies, please.
            Many thanks,
            Paul
            • Jailhouse
              • Sep 2016
              • 388
              Per Google Translate, "Estnisches Symphony Orchester" and "Staatliches Kammerorchester Zilina" are German for Estonian Symphony Orchestra and State Chamber Orchestra Zilina, respectively. (Zilina is a city in Slovakia.) I suspect they are correct as far as they go; you might want to change the first to Estonian National Symphony Orchestra as per Discogs, and the second to Zilina State Chamber Orchestra.
              • monsterjazzlick
                • 1764
                Thanks JH,
                That's great. I really was not sure whether or not to trust what I was reading in my online searches. And the sleeve notes are pretty poor (possibly because the CD was very cheap in price).
                Paul
                • monsterjazzlick
                  • 1764
                  Regarding the above CD of Haydn (Symphony Nos. 92 & 103), there is (which I assume to be an equivalent logging scheme to that of an 'opus') the references: 'Hoboken 1/92' and 'Hoboken 1/103'.
                  Some sources use, instead: 'H1/92' and 'H1/103'. I assume this is referring to the same number?
                  Would you use the abb. 'H' or the full word 'Hoboken', please? As previously discussed, for opus I use 'Op.' and for Bach's works I use 'BWV'.
                  Many thanks,
                  Paul
                  • Jailhouse
                    • Sep 2016
                    • 388
                    Yes.
                    That's a personal preference item. 'H' saves a few bytes of text, while 'Hoboken' won't have you scratching your head several years hence wondering what the devil 'H' means.
                    My preference is to ignore it. But you probably would have guessed that.
                    • monsterjazzlick
                      • 1764
                      Hi JH,
                      Actually, I am surprised to hear you chose to omit it!
                      I will go with:
                      'Hoboken'
                      Paul
                      • Jailhouse
                        • Sep 2016
                        • 388
                        Hi JH,
                        Haven't you been paying attention to me?
                        I would omit it if I were to rip the CD (I don't own a copy), as I find the Symphony number to be sufficient for my use.
                        • monsterjazzlick
                          • 1764
                          That's fair enough. I am only really entering this particular data for the sake of completeness; and because I never want to have to rip/tag my CD collection again, and the 'opus' (or similar) number may be something I require in the future (who knows!).
                          • monsterjazzlick
                            • 1764
                            With reference to the aforementioned Haydn CD, sources appear to use:
                            Usually, a slash indicates that the subject is number-something out-of-something. For example:
                            1/5 = part-one out-of-five
                            The 'Hoboken', suggests, to me, that this is in relation to the SYMPHONY number. But, why have a leading number '1' (ie. before the forward slash)? Obviously the latter number is the symphony number.
                            I don't know how many symphonies Haydn composed, but if we said 125, then I would have thought the logging scheme would read:
                            'Hoboken 103/125'
                            Many thanks.
                              • 4015
                              I would let go of that idea as I suspect you will be editing your tags in the future.
                                • 5747
                                Yep, a never ending job as one reconsiders new ways to organize things in the future, or a new player doesn't work the same with your tag scheme, etc. The good news is that you never have to RIP your CDs again, if ripped to lossless FLAC. And tag editing is downright easy and quick (and sometimes can be done in bulk) as compared with ripping.
