3 codecs display error messages at installation
  • CyndiBop
    • Feb 2018
    • 11
    Re: 3 codecs display error messages at installation
    Originally posted by Dat Ei
    You have 32bit dBpa running. Only Spoon can help to get the 32bit version of Length Split running (is included in the one install file).
    Ok thank you, will wait for a help from Spoon, if it will come
      • 43926
      This is not it, the installer is being blocked by some other security software.
      You might have some anti-malware program you do not even realize you installed.
        • 1748
        Hey Spoon,
        I have tried to install the 32bit version "Length Split R2" on two different Windows 10 systems. One system is protected by ESET, the second by Avira Free Antivirus. Both systems showed the same error message:
        "This installation is corrupted, please obtain a new copy."
        This message comes up, even if I disable the real time protection of Avira or uninstall Avira completely.
        Could you please try to install the 32bit version of "Length Split R2" on a 64bit Windows 10?
          • 43926
          We have re-code signed these installs, please redownload and try again.
            • 1748
            That looks better. I have just startet the new Length Split with right shift key holded down on W10, 64bit and with ESET running. It came up with no problems. I've canceld the further installation.
