Page 41 of 50 FirstFirst ... 313940414243 ... LastLast
Results 601 to 615 of 738
Thread: RE: Ripping Level Question (help?)
  1. #601
    Join Date
    Nov 2007
    Location
    Florida, USA
    Quote Originally Posted by monsterjazzlick View Post
    OK, cheers Gary. If I am mostly going to use Foobar, and quite possibly purchase a Amazon Fire Tablet (as the faulty Sony has been returned), then would you bother (if you where I!) to change all of my '/' to a ';'? Paul
    id wait for tablet and see how it reads things
  2. #602
    Join Date
    Jul 2017
    Location
    Wirral, UK
    Quote Originally Posted by garym View Post
    OK, thanks Gary. I am still screaming and jumping up & down at Amazon for a refund for the faulty Sony Walkman. The dispute has dragged on for nearly 8 x weeks now! Paul
  3. #603
    Join Date
    Dec 2008
    Location
    London, UK
    You probably need to get your head around the difference between a single tag and a multi-value tag and which tags are single and multi-value, as not all tags are multi-value e.g. the Album tag.
    For a multi-value tag, Illustrate uses the semi-colon purely as a searator for display purposes. Example, Composer and Composer Sort are multi-value tags:
    Composer Sort = Lennon, John; McCartney, Paul
    here, composer sort holds 2 separate data values Lennon, John and McCartney, Paul with no semi-colon. The semi-colon is purely for display.
    However for a single tag:
    Album = Weebles; The Greatest Hits
    here, album contains a single value Weebles; The Greatest Hits with the semi-colon contained within the data.
    What makes this even more complicated is that single and multi-value tag support differs for different file/tagging formats (ID3v1, ID3v2.3, ID3v2.4, Vorbis Comments, iTunes MP4, WMA, APE etc.) and is not standardized across all server/client/player software.
  4. #604
    Join Date
    Jul 2017
    Location
    Wirral, UK
    Thanks a lot Mville. That's great. I will have a look at this in more detail and see how to applies to my tagging methods. Cheers, Paul
  5. #605
    Join Date
    Jul 2017
    Location
    Wirral, UK
    Question Re: Ripping Level Question (help?)
    Hi Mville,
    I was toying with your kind suggestions earlier; as my new Amazon Fire HD tablet arrived - due to the Sony Walkman getting ditched. I will try out putting the SD card into the device to see how it responds to the tagging I have made so far. After which, I may, or may not, replace the '/' I have used with ';'.
    In the meantime, I wanted to ask, please:
    I ripped a CD by 'The Brecker Brothers'. Please see tagging protocol used (as Inserted Images):
    I would like them to appear in Foobar (and other playback devices/softwares) as 'Brecker Brothers, The' - but the above tagging does not seem to produce this result. Here is how the folder appears (position) in My_Music:
    Many thanks,
    Paul
  6. #606
    Join Date
    Nov 2007
    Location
    Florida, USA
    That's not foobar you show in BB_3. That's your explorer folder listing which is not the tags at all. You've named the folder "The Brecker Brothers", thus it shows up that way. For INSIDE foobar2000 and the tags, I'm sure it does show up as "Becker Brothers, The" using the ARTISTSORT tag.
  7. #607
    Join Date
    Jul 2017
    Location
    Wirral, UK
    Hi Gary,
    Yes, screenshot 'BB_3' is of My_Music on my Windows PC; which is why the preceding sentence reads:
    Here is how the folder appears (position) in My_Music ...
    The above mentioned folder was - as is always the case - automatically created by dBpa. But perhaps the 'naming' was a result of incorrect tagging, on my part?
    Cheers,
    Paul
  8. #608
    Join Date
    Jul 2017
    Location
    Wirral, UK
    ... should I change the Artist and Album Artist both to:
    (This would then match the tags for: Artist Sort and Album Artist Sort.)
    And also manually change the folder name (in My_Music)?
    I have a few Jazz groups with names beginning the the word 'The' (eg. 'The Mahavishnu Orchestra'), and so this is something I need to address.
    Paul
  9. #609
    Join Date
    Nov 2007
    Location
    Florida, USA
    Hi Gary,
    Cheers,
    Paul
    You haven't tagged wrong at all. But if you want your folder names to use ARTISTSORT instead of ARTIST, then you need to change your dynamic naming string to reference ARTISTSORT instead of ARTIST (or do an "if" to do ARTISTSORT if it exists).
  10. #610
    Join Date
    Jul 2017
    Location
    Wirral, UK
    Cheers Gary,
    That's helpful.
    It is only for band-names which include the word 'The' that I wish for folder-name to follow the ARTISTSORT tag.
    I would prefer to not be switching the dynamic naming string (for bands with and without the name 'The').
    At the moment the Windows folder-names are in christian-name alphabetical order.
    I am thinking that the best thing to do might be to manually type: "Brecker Brothers, The" (and same for similarly named bands) in both the ARTIST and ALBUM ARTIST fields. I am guessing that would achieve the desired results without having to switch naming strings.
    Cheers,
    Paul
  11. #611
    Join Date
    Nov 2007
    Location
    Florida, USA
    yeah, manual fixing on these few things might be the easiest.
  12. #612
    Join Date
    Jul 2017
    Location
    Wirral, UK
    Gary, I will give that a try out. I'll run a re-rip just to test it fully. Cheers.
  13. #613
    Join Date
    Nov 2007
    Location
    Florida, USA
    Why re-rip. Just change folder name and edit the tags.
  14. #614
    Join Date
    Jul 2017
    Location
    Wirral, UK
    Cheers Gary, seems to be sorted now!
    I will follow this protocol for all such band-names containing 'The'.
    Paul
  15. #615
    Join Date
    Jul 2017
    Location
    Wirral, UK
    Because I wanted to test it out from the outset and be sure that the naming scheme worked accordingly. Then I would know it's another minor hic-cup done and dusted with. The CD was still in the drive and it only took 3 x mins.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
