What hides behind these strange Flac Settings ???
  • OggZealot
    • Jan 2004
    Low/Medium/High ???
    What does that means ???
    I know fast/default(or standard)/best (Q0/Q5/Q8) which are the official Flac naming but where do these Low/Medium/High come from for Flac ... plz Spoon don't Monkeyfy (see .ape seetings) Flac settings ... it's not clear at all ... & as a FlacZealot over Monkey Audio I dislike this naming much :thumbdown I hope it get fixed in future flac plugins (This is a request ...)
    So the question is what real official Flac setting hide behind Low/Medium/High ??? :blush:
    Thks for Help
    Edit: I made some encoding test to see if I get the same result with flac.exe in Q8 & your dbMC with setting high ... result were awfull 1: flac. exe was much faster 2: flac.exe Q8 was smaller than your dbMC flac output with setting high ... I have seen enought forget about my question I will not use dbMC ... the flac plugin is very bad (It is enought to decode but not to seriously encode)
    Note to Spoon: ... with such a bad Flac plugin it's not surprising you prefer Monkey Audio over Flac :komisch9:
    Bye bye all, gonna find a better ApeToFlac converter ... :(
    Edit2: Found ... Frontah (& Speek's Multifront)
