Multiline comment box ?
  • StephenT137
    • Dec 2016
    Hi, I just had to rebuild my computer and when i reinstalled dbpoweramp upgraded to the newest version, was previously using 15.3 (and before that earlier versions). Is there a way to get the multi-line comment box back in 16 on Windows. If not, can I install 15.3 side by side with 16 ?
    • 43928
    Re: Multiline comment box ?
    You would have to uninstall R16 and install R15, copy the CD Ripper program and rename it (in Program Files) to CDRipper1.exe, then install R16, if you run the CDRipper1.exe then you will have R15 cd ripper.
