Page 1 of 2 12 LastLast
Results 1 to 15 of 16
Thread: HDCD not detected
  1. #1
    Join Date
    Sep 2016
    HDCD not detected
    Hi, I am at last getting to grips with the software and have worked out how to set the DSP to detect HDCD's and rip them to flac which shows up as 24bit in the Tag, great,
    but ...
    I have several HDCD's which the software is not detecting as such, eg :
    Neil Young - Silver & Gold
    Neil Young - Greendale
    Neil Young - Filmore East.
    I know for certain Silver & Gold and Greendale are as I used to have an Arcam alpha8SE CDplayer which showed them as such with the red light. My current CD is the Arcam CD192, which will decode HDCD but does not have an indicator so I can not longer confirm for certain about others that should be.
    any suggestions welcome... or a possible software update?
    cheers
  2. #2
    Join Date
    Dec 2008
    Location
    London, UK
    Re: HDCD not detected
    I am running dBpoweramp Music Converter R15.3 and in CDRipper my Neil Young - Greendale CD is showing as HDCD for all tracks.
    HDCDs is a bit misleading, as in reality it is more track dependant than CD dependant i.e. you can have a CD where not all the tracks are HDCD encoded.
    Also, depending on how you listen to your audio library, ripping using the HDCD DSP might not be the best way forward.
    For more information, read here: Ripping HDCDs: Best practices?
  3. #3
    Join Date
    Sep 2016
    cheers, i'll have a read of that. Ripping audio files to my network drive is really for convenience listening with either Sonos or my Cambridge Audio network player, however I am soon to invest in an Astell n Kern DAP and am just trying to get the best out of my collection where possible.
    I suppose it could rely on the PC i'm using to rip the CD's...
  4. #4
    Join Date
    Dec 2008
    Location
    London, UK
    Quote Originally Posted by VinylDunc View Post
    I don't think so. What version of dBpoweramp Music Converter are you using?
  5. #5
    Join Date
    Dec 2008
    Location
    London, UK
    How do you intend to play files from the network drive, on the Astell n Kern DAP?
  6. #6
    Join Date
    Sep 2016
    the lastest one 16.1.
    I find it odd that some HDCD's are detected and some are not thats all. I was just viewing another thread on actual Optical Disc Drives and rates of accuracy
  7. #7
    Join Date
    Sep 2016
    I will be transferring files to a 128Gb micro sd card :-)
  8. #8
    Join Date
    Dec 2008
    Location
    London, UK
    If the Astell n Kern DAP supports HDCD playback, there is a possibility that it will decode the ripped HDCD files from the 128Gb micro sd card.
    If this is the case, then there is NO need to rip CDs with the HDCD DSP. I would check this with Astell n Kern.
  9. #9
    Join Date
    Dec 2008
    Location
    London, UK
    Perhaps there is a bug in R16.1.
  10. #10
    Join Date
    Sep 2016
    ... so just rip to flac in normal 16bit mode? I thought that would just create a 16bit audio file without any additional info?
  11. #11
    Join Date
    Dec 2008
    Location
    London, UK
    Yes. The 16-bit flac file will still contain the HDCD information, just as the 16-bit audio on the CD contains the HDCD information.
    This is how I rip my HDCDs, i.e. to flac without the HDCD DSP and I use foobar2000 with the HDCD decoder to play my flac library.
    The HDCD DSP can be used if you have no HDCD compatible software/hardware.
  12. #12
    Join Date
    Sep 2016
    thanks for your help, I'll see how I get on. Will contact A&K and Cambridge too see what they say, post replies if usefull
  13. #13
    Join Date
    Sep 2016
    ... however, back to my initial problem, If dbpoweramp is not detecting that it is a HDCD then there will not be a Tag on the flac file
    to be honest I only have about 20 HDCD's, but my OCD won't let it lie
  14. #14
    Join Date
    Sep 2016
    OK, so just to end my own thread :
    - I've loaded dbPoweramp (registered) on a newer PC and that is detecting the HDCD's better. "Silver & Gold"s first track still does not get a HDCD tag but the Bit Depth dsp does take it to a 24 bit file. *HappierNow
    - Astell & Kern suggested that their DAPs would read the 16 & 24 bit files as is...
    cheers
  15. #15
    Join Date
    Dec 2008
    Location
    London, UK
    Yes, but are they saying whether the DAP will recognise that the 16-bit audio file is HDCD encoded. and decode it?
Posting Permissions
  • You may not post replies
  • You may not edit your posts
