Doesn't Rip
  • fugno
    • Apr 2009
    Doesn't Rip
    OK here's a strange problem, I've been using reference 15.3 and it was working fine until this evening. I placed a CD in the drive and the ripper popped up on the screen as usual and I clicked the rip button but the progress meter stayed on zero on the first song I waited for a while and nothing happened so I tried to cancel the rip but the program froze. I hit the eject button on my drive and when it opened the program status bar started going like the CD was being ripped and even created a folder with the song titles but they won't play. I figured my drive was defective but I can rip a CD just fine with EAC. I uninstalled reference 15.3 and slapped down another $20.00 bucks for reference 16 and installed it but get the same problem I'm running Windows 7 64bit, Wasup?
    • 43930
    Re: Doesn't Rip
    Run this:
    to reset all the settings, then reinstall R16 and try to rip that cd without changing any options.
    • fugno
      • Apr 2009
      Re: Doesn't Rip
      Thank you sir that did the trick. I like the new layout of R16 keep up the good work!
