TTrack Hi=eirarchy Problem with Downloaded Albums
  • Tom Swaman
    • Oct 2011
    • 258
    Due to both storage space and the ability to economically atore and to backup high quality music files in FLAC, I have been downloasing many classical albums. Many of these downloaded albums are missing track numbers in ther metadata. As such, when the album passes through Asset to a renderer such as LINN Kinsky or Lynn Kazoo, the tracks play out of-order unless each track is hand-loaded everu time. Needlrdd to say, this makes downloading music tantamount to uselessness.
    I find that if I number every track by hand as a fraction of the total number of tracks in each alkbum, I now have a seemingly perfect work around. However, this is way to cumbersome and time-consuming in a large number of album folder downloads.
    Is there a simple, efficient way of numbering track files in an album folder so as to preserve the proper hierarchy in the downloaded album folder?
    Thanks nuch,
    Tom
    • 43989
    Re: TTrack Hi=eirarchy Problem with Downloaded Albums
    The only way is to tag them by hand.
      • 4015
      Do the filenames contain track number information?
      • Tom Swaman
        • Oct 2011
        • 258
        Mville,
        No these do not. By the way, I am talking about the downloaded folders of a major record company. I have contacted them, but I have not received a reply.
        Regards,
        Tom
        • Tom Swaman
          • Oct 2011
          • 258
          Spoon,
          Thank you as always. I feared your answer, but I expected this.
          Regards,
          Tom
            • 4015
            If the files have no track number (in either the filename or metadata) then there is no player that will be able to determine the album track order. When you view the files in the folder, I assume the files are just in alphabetical order i.e. in terms of album track order, they are random.
            It would be interesting to get the record labels reasoning for this.
            • schmidj
              • Nov 2013
              • 500
              Well, I think the record company owes us decent tags, but I've seen downloaded fils with no tags before.
              If you downloaded the tracks from the site in track order, sorting on the file creation date kept by Windows should put them in track order, but then you will have to change the filenames to start with the track number and/or manually add the track number tag to each file. Someone who has used mp3tag ( or possibly the tagging capabilities of dBPoweramp) more than me may be able to tell you if there is a way of automating this with a script based on the file date created.
