Asset Upnp for Synology
  • royaltiger
    • Jun 2004
    • 13
    #61
    Re: Asset Upnp for Synology
    Thankyou, that is now working by changing to LPCM, I didn't understand why it could read the wav file in normal synology server, but not the AssetUPnP
    • Hercules
      • Dec 2016
      Just a reminder for everyone, update DSM 6.0 to 6.1 will erase the whole Asset UPnP so have to install again
      • ac16161
        • Mar 2012
        • 116
        #63
        But fortunately does not remove configuration, so reinstall is quite painless.
        • dikkiedirk
          • 32
          #64
          You have configured asset and pointed it to your music location?
          To which path should it point? Is it just the sharename like music or should Volume1 be included like Volume1/music? Tried both but still Asset cant find my music.
            • 43929
            #65
            It would have to be the local path, if you SSH into the synology and browse to the location of your music, such as:
            cd /usr/
            with the correct path(usr was just an example), once you can see your music, that is the path you need to enter into asset.
            • ac16161
              • Mar 2012
              • 116
              #66
              Originally posted by ac16161
              Is there any reason why the Intel debian 64 build of Asset would not run on an Intel Atom 64 Synology NAS? Am looking at the DS1515+. Thanks.
              For anyone for whom this may be of interest, can confirm the Intel x64 build runs on a Synology 416play without a hitch.
              • tegetege
                • Jun 2017
                I have purchased Asset Upnp for Raspberry Pi and installed it on my Synology DS416slim. It runs fine. However, as noted above it gets erased every time a DSM update is installed. Synology regularly (at least monthly) releases updates (mostly to fix vulnerabilities), so one has to re-install Asset Upnp quite often.
                Is there any chance that a proper synology package of Asset Upnp will be available from the package center in the future? Or at least not having to reinstall every time a DSM update is released would be really great.
                • tegetege
                  • Jun 2017
                  • hecaitomex
                    • May 2016
                    Changes for installing AssetUPnP R6 on Synology Nas:
                    As the folder structure has been changed, the main directory "bin" is now installed at "/usr/bin/asset/Asset-R6-Linux-x64-trial/bin" instead of "/usr/bin/asset/bin"
                    Therefore you have to either:
                    change asset.conf line 3 to "exec /usr/bin/asset/Asset-R6-Linux-x64-trial/bin"
                    or
                    move the new "bin" folder to the old position via winscp or ssh (from "/usr/bin/asset/Asset-R6-Linux-x64-trial/bin" to "/usr/bin/asset/bin")
                    Database directory is still "/root/.dBpoweramp"
                    Before installing the new Version 6 i recommend to delete the old Version, as there might be conflicts in regard to the new image-layout.
                    kind regards
                    h
                    • hecaitomex
                      • May 2016
                      @tegetege:
                      you may try the following instead of reinstalling asset after it has been wiped due to a large DSM-update:
                      logon your Nas with winscp and copy the folder /usr/bin/asset (since Version 6 /usr/bin/asset/Asset-R6-Linux-x64-trial) onto your PC.
                      as DSM updates dont touch the "asset.conf" file nor the database /root/.dBpoweramp you should just have to copy back the folder once it has been wiped, and restart your Nas.
                      I have not tried this way as there was no update since i had this idea, but if there are no user-right problems with that folder it should probably work and save a lot of typing.
                      kind regards
                      h
                      • rmadone
                        • Jul 2018
                        HELP, I have a Synology DS412+ I've followed the instructions above and when I get to step "cd /usr/bin/asset/bin./AssetUPnP", I get the line "-ash: cd: /usr/bin/asset/bin./AssetUPnP: No such File or directory". I am not an advanced programmer, so I'm stuck here and would appreciate any assistance at moving forward. I'm trying to get Asset on my NAS for use with a Simaudio Mind 180.
                          • 43929
                          #72
                          cd /usr/bin/asset
                          ./AssetUPnP
                          or
                          ./Asset-R6-Linux-x64-trial
                            Super Moderator
                            • 1365
                            #73
                            Dear userbase,
                            An official Asset package for Synology has just been released:
                            Current version: R6.2 beta 15 Downloads: <now released> (Synology link until it is published) http://www.dbpoweramp.com/beta/Asset-R6.2b15.spk Changes since R6.1 Fixed AAC decoding on QNAP with 64-bit ARM processors. Warning on corrupted database file, shown when accessing web config. Standalone builds for ARM64
                            It includes binaries for every mainstream CPU, just like the QNAP version; the correct binary is launched automatically.
                            If you encounter any issues, please post the exact NAS model and DSM software version.
                            Happy testing.
                            • rmadone
                              • Jul 2018
                              Originally posted by PeterP
                              Dear userbase,
                              Happy testing.
                              Thanks for the update to make this happen! So far it's installed and allowing me to view some of my content. I've got a large collection, so assuming it takes a while. I'll likely purchase soon, so which option do I select on your Illustrate Asset purchase page?
                              • psweetie
                                • Feb 2016
                                • 68
                                #75
                                Hi Peter
                                I installed the beta3 package and that worked fine. I found the .dBpoweramp directory in /usr/syno/etc/packages/Asset/.dBpoweramp and manipulated things as I wanted. I have just installed the beta 4 package and it didn't read the existing configuration, the /usr/syno/etc/packages/Asset directory is there but empty. The .dBpoweramp directory must be somewhere but can't seem to find it? Where is it please and would installing a new package automatically delete all existing settings?
                                Philip
