Problem loading any DSP's
  • tflood
    • Jul 2004
    • 30
    Hey hey
    Not sure if i should post this or email... anyway...
    I had a slightly outdated version of dBpoweramp converter and DSP effects installed (all registered). Running win10. I noticed that when i am in the conversion menu for a file, i go to add a DSP, and there are none. I have to click "Install DSP effects now..." and I have no idea why. I don't know what to do. I uninstalled everything and reinstalled the newest (just the converter and DSP's), but the same thing prevails. It even has the "Force Non-Live" and "Fade" effects still loaded from some time in the past. Dunno..
    Thx anybody
    Tom
    • 43936
    Re: Problem loading any DSP's
    Which version of dBpoweramp do you have?
    • tflood
      • Jul 2004
      • 30
      Hey Spoon!
      15.3
        • 43936
        You are best to uninstall with this method:
        Then reinstall both DSP and Music Converter (do the converter first).
        • tflood
          • Jul 2004
          • 30
          Heyo
          I did all steps to perfection. All the unintalling, restarting, running the tool, then reinstalling in the right order. Sorry, took me a bit to get to this. All the old DSP's were cleared from the Options/DSP Effects list, but still, when I go to load an effect, it takes me to "Install DSP effects now...". Wowweee i wonder why?!
            • 43936
            You have dBpoweramp reference? this is needed for DSP effects.
            • tflood
              • Jul 2004
              • 30
              in the configure menu it says i have registered power pack but nothing about reference
                • 43936
                The Powerpack is ok for DSP effects.
                Check where dBpoweramp is installed, there should be a folder 'DSPs' and it should be populated with dlls.
                • tflood
                  • Jul 2004
                  • 30
                  Found the folder. All it has is _MultiEncoder.dll
                    • 43936
                    Where is dBpoweramp installed to? and when you install the DSP effects where does it install to?
                    Which version of dBpoweramp do you have? the 32 bit or 64 bit version.
                    • tflood
                      • Jul 2004
                      • 30
                      Version:
                      dBpoweramp 64-bit: Registered Power Pack
                      Release 15.3
                      PerfectTUNES: manage your audio collection, with a helping hand
                      Asset UPnP: UPnP (DLNA) Audio Server
                      Directory for poweramp:
                      C:\Program Files\dBpoweramp
                      I think i may know the problem. I assumed that my particular registered version of dB with powerpack registered had the powerpack built-in. I thought dBpoweramp-dMC-DSP.exe would have powerpack built inside it. Maybe i need to download a powerpack file separately for installation? I actually can't find any powerpack file to install within my folder where i keep downloads.
                        • 43936
                        When you install the DSP effects where does it install them to?
                        • tflood
                          • Jul 2004
                          • 30
                          C:\Users\tom\dBpoweramp
                          • tflood
                            • Jul 2004
                            • 30
                            i don't know why it installed there. I hate all the dumb "user" directory, and really, user anything in windows. Anyway, there in the folder are all the DSP dll's. But, when i go to Add DSP Effect --> Load, the program searches only for *.dspeffect. It doesn't search for .dll
                              • 43936
                              Uninstall the DSP effects, and reinstall to:
