Help with volume levels
  • gemeit
    • Sep 2015
    • 22
    Hi I have around 2000 apple lossless tracks what I would like to do is listen to them all at the same level. I play them Via a Hegel H160 streamer / amp I don't think it recognises relay gain so how would I convert them all to apply lossless to achieve this do I just convert using volume normalisation if so what option is it peak to peak or replay gain very new at this so not sure at all what to do
    • 43983
    Re: Help with volume levels
    Use volume normalize DSP effect, set to the replaygain option, and convert Apple Lossless >> Apple Lossless, but in a different location, so you do not overwrite the original ungained files.
    • gemeit
      • Sep 2015
      • 22
      Thank you
      • gemeit
        • Sep 2015
        • 22
        Is there a way I can do this but keep the same folder structure
        • gemeit
          • Sep 2015
          • 22
          Think I have got it using [origpath]\[origfilename]
