Final track needing Re-rip
  • mdm1979
    • Mar 2016
    • 9
    About 1 in every 10 discs or so often requires a final track Re-rip. This is despite being a new disc. Are there any settings I can adjust to avoid this yet keep ripping the final track accurately?
    • 43930
    Re: Final track needing Re-rip
    It is specific to your CD drive, only replacing it would change the outcome.
    • mdm1979
      • Mar 2016
      • 9
      Should I be ripping these defective last & second last tracks as 'secure'? It's very time consuming and I'm unsure if it's necessary.
      • Oggy
        • 697
        Depends if you don't mind, potentially having errors on the last two tracks, of one in ten albums! Tha
        Try those discs in a different drive, if this is occurring regularly. One in ten adds up to a large number of tracks with errors, and potentially a lot of lost time re-ripping frames.
        1 in 100, i'd live with, and re-rip, but 1 in 10, on a regular basis, potentially shows a problem. Clean the disc and try again, if still errors in the last two tracks, try another (different model) drive. 100 discs out of a 1,000 with errors, is a lot of lost, last tracks.
        Out of interest, are the discs that give errors, longer than 74mins?
