Asset 5.1 and chromecast audio
  • DaFork
    • Jan 2011
    • 67
    Hi all,
    Just got me a Chromecast Audio. Great little device, for our kitchen radio which used to have an airport express (not in use anymore). In the living room we have a Linn DS, different league. All my own CD albums (some 800) are ripped using dbpoweramp cd ripper in accurate mode, stored in m4a/alac.
    Using Asset 5.1 (premium) as my music database. The linn plays everything, the chromecast audio does not play the alac (using Bubble upnp as a control point on my android phone) but it does play internet radio (tunein) using the browse tree if Asset.
    For the Linn i would want to play the m4a/alac as is, for the Chromecast (which does not support alac) i would need to transcode the alac to wav on the fly when playing. Can I distinguish transcoding per media renderer? How to do so?
    Another thing that puzzles me is that when playing tunein through internet radio in Asset, my radios seem to get a stream from the ip address of the local server running Asset (192.168.0.3/...). Can you also play directly from the source stream that's retreived from the web, other than local caching?
    Merry xmas,
    DaFork
    • 4015
    Re: Asset 5.1 and chromecast audio
    Asset UPnP Configuration >> Advanced Settings >> Genereal Settings >> Edit Override settings
    Then, in Rule Based Profiles (left-hand window pane) add the following:
    =MyDevice
    [ForceToWAVE]
    .alac
    where MyDevice is the name for your chromecast found in Known Control Points (right-hand window pane).
    You can also use the following forced streaming options:
    [ForceToMP3] [ForceToLPCM] [ForceToSINGLE]
    Last edited by mville; 12-26-2015, 12:40 PM. Reason: added other forced streaming options
    • DaFork
      • Jan 2011
      • 67
      Wow, fantastic tip.
      The control point in my specific case is 'Android/5.1.1 UPnP/1.0 BubbleUPnP/2.5.5.1'
      Do I need to enter that entire string? This app is updated frequently, don't want to change this every time it does update and change this string. Or can one use wildcards?
        • 4015
        First of all, try it using the entire string, to check it is working.
        Hopefully, Spoon can answer regarding the use of wildcards for the control point name.
          • 43991
          It will match part of it also, so you can specify just the first section until /
          An easier option would be to set ALAC to decode 'as wav' for everything.
          • DaFork
            • Jan 2011
            • 67
            Got it working, great to get perfect feedback.
            Related followup question, the chromecast audio supports up to 24/96. Higher sampling frequency does not play back now. Can I cap the samplimg frequency for this device/control point on flac/alac files to 96KHz?
