A little help with a folder structure condition?
  • TomBomb
    • Oct 2015
    Hi !
    First, hello, I'm new here!
    I've been trying to setup something in dbpoweramp Music Converter, but I failed, so I come here for help. Shouldn't be particularly complicated compared to some requests here, so I hope someone can help
    So here's the thing:
    When converting music and placing it neatly in my music folder, there are two cases:
    If the album only has one disc, I want to place it in a folder that looks like this:
    Artist \ Album \ Tracks
    If there are several discs, it should look like this:
    Artist \ Album \ Album, Disc * \ Tracks
    In my collection, and this includes the FLACS I'm usually converting to, if there is only 1 disc, then I remove the disc value from the mp3tags, there's no value at all. There is only a disc value for albums with several discs.
    So basically, I'm just trying to set a condition: if there is no disc info, skipc creating that folder. If there are several discs, create a folder for each disc.
    Is that doable?
    Thanks in advance!
    Re: A little help with a folder structure condition?
    What is your current Naming string, in CDRipper?
    • TomBomb
      • Oct 2015
      Currently, without my failed attempt at making the condition, just like this:
      [album artist]\[album]\[album], Disc [disc]\[track] - [title]
        • 6059
        try this
        [IFVALUE]album artist,[album artist],[artist][]\[album][IFMULTI] \[album], Disc [disc][]\[track] - [title]
          Try this:
          [album artist]\[album]\[album][IF][disc_total],=,1,,_COMMA_ Disc [disc][]\[track] - [title]
            There's more than one way to skin a cat ...
              • 6059
              And if you want the string to also automatically handle compilations, use this instead. For compilations, it won't put album under an artist, it will simply put it under a "Compilations" directory, with album subdirectories underneath. And note that this string also handles cases where you either have albumartist or only artist.
              [IFCOMP]Compilations\[album] [IFMULTI] \[album], Disc [disc][]\[track]-[title]-[artist][][IF!COMP][IFVALUE]album artist,[album artist],[artist][]\[album][IFMULTI] \[album], Disc [disc][]\[track]-[title][]
                • 6059
                great minds think (almost) alike!
                • TomBomb
                  • Oct 2015
                  Thanks guys,
                  I tried both options, but unfortunately, neither of them works. The first one doesn't create a disc folder, and the second one always creates one (with no disc number) :(
                    It has also been said, great minds don't think alike, for that is why they are great. I like that.
                      At the top of the CDRipper window what do you have for Disc, 1/1, 1/2, 2/2 etc.?
                      • TomBomb
                        • Oct 2015
                        In CD Ripper, it doesn't matter much because once the discs are ripped I change these values. If there is only 1 disc in the album, then these values are empty (I remove them). If there are several discs, then there will be the disc number and the total number of discs.
                        Once I got my FLACs correct, then I use the Batch converter to create the MP3s I'll use (the FLACs are kept away), and that's when I need this, because Batch converter creates new folders for the MP3s and doesn't place them exactly where I need them in the process.
                        • TomBomb
                          • Oct 2015
                          Double post
                            • 6059
                            Thanks guys,
                            hmmm, odd as I use the one I posted often (except I don't include the album name along with the Disk subfolder. Try this, which is exactly what I use:
                            [IFCOMP]Compilations\[album] [IFMULTI] \Disc [disc][]\[track]-[title]-[artist][][IF!COMP][IFVALUE]album artist,[album artist],[artist][]\[album][IFMULTI] \Disc [disc][]\[track]-[title][]
                            this works whether the disc field is empty or has a value.
                              • 6059
                              And are you sure that the file has a "DISC" tag field when you look at these files with dbpa ID TAG EDITOR (right click on the file to see this option in file explorer). For example:
