Problem with Fraunhofer IIS
    • 1748
    Hey Spoon,
    I've tried to convert a 24bit / 192kHz flac file with the Fraunhofer IIS codec into a 320 kbps CBR mp3. No matter if I chose fast or high quality, the resulting file is defect and produces nothing but a popping sound at the beginning - the rest is silence. Is this a known issue?
    • 43928
    Re: Problem with Fraunhofer IIS
    You are using the 32 bit version of dBpoweramp and our fraunhofer mp3 codec?
      • 1748
      Yes, I do. Fraunhofer is only compatible with the 32bit version of dBpa.
        • 43928
        Try using DSP effects resample and Bit depth to reduce the file whilst converting.
          • 1748
          Hey Spoon,
          I will try this next week. In the meanwhile I've tried to convert the flac file with the lame converter successfully.
          Is this a known problem of the Fraunhofer converter? Is there a chance for a fix in the future? The Fraunhofer codex is the only reason for me to stay with the 32bit version of dBpa. Will we ever see a 64bit version of the Fraunhofer?
            • 43928
            Fraunhoffer is effectively unsupported as we can no longer develop with it.
              • 1748
              Thanks for the statement. For me it's time to change to lame and the 64bit dBpa version...
                • 4015
                Originally posted by Dat Ei
                Thanks for the statement. For me it's time to change to lame and the 64bit dBpa version...i
                I'm interested in why you have been using the Fraunhofer encoder and not the lame encoder. Is there any particular reason why?
                  • 1748
                  Hey mville,
                  it is not the result of intensive testing. It's more the trust in and respect for Fraunhofer, (one of) the inventors of mp3. So you may call me old-fashioned...
                  But aside of that: the encoding of Fraunhofer is even quicker than that of lame.
                    • 4015
                    Thanks for the clarification.
