DSD to PCM Conversion
  • dminches
    • May 2009
    Can someone tell me how long it should take to convert a 1 GB DSD (DSF) file to PCM? I have a pretty fast workstation (i7-4770k with 32 GB of ram) and it seems to take forever to convert. It takes about 10 minutes to convert a 60 minutes DSD file in Korg's audiogate.
    Maybe I have some settings wrong?
    • 43980
    Re: DSD to PCM Conversion
    How long does the conversion take?
    • dminches
      • May 2009
      Honestly, I never get to the end. The time keeps counting up and I terminate it. I just restarted it. After 3 minutes it says that there are 3 hours remaining. Something isn't right. It decodes and encodes 24/96 flac/wav super fast.
      10 minutes in, 5% done, 3 hours to go.
        • 43980
        You have any smaller files you can test with?
        • moviestar
          • Jul 2015
          is DSD to PCM (wave) or flac conversion via dBpoweramp actually bit-perfect & lossless? when converting .dff DSD files.
          in settings, the recommended output is still 96/24 and for anything above 176kHz there is still this ultra-sonic noise warning given. In case it is lossless, is it lossless from setting 176kHz onwards (176 and higher)? or should I rather set 192kHz output just to be sure?
            • 43980
            No DSD to PCM is bit perfect, it is not possible like that.
            Every DSD encoded signal has ultrasonics, it is how the format is designed.
