20 Bit CD Won't Play or Rip
  • musicmafia
    • Jan 2008
    • 51
    Creedence Clearwater Revival "Green River" 20 bit remaster.
    CD Ripper shows Track Zero (greyed out) hidden track and shows Track 1 as being 335 hours long.
    The data is displayed wrong (song titles where artist should be, etc.
    Plays fine on a standalone CD player.
    No track will play or rip. Tried from 2 different disc drives. I'm stumped.Click image for larger version
    • 43930
    Re: 20 Bit CD Won't Play or Rip
    Try enabling Defective by design from the options menu.
    • musicmafia
      • Jan 2008
      • 51
      hey spoon, thanks for your help. unfortunately this option appears to be greyed out and i cannot tick the box to choose this option.
      i also tried installing hdcd dsp and that had no effect.
        • 43930
        Defective by design requires the Reference version. HDCD would not help.
        • musicmafia
          • Jan 2008
          • 51
          how do i determine what version i have? if i upgrade to reference will i be able to rip these types of cds? thx, MM
            • 43930
            Run 'Configure dBpoweramp' it will show the version. There are no guarantees that Defective by Design will rip that cd, as it half depends on your drive.
            • musicmafia
              • Jan 2008
              • 51
              Tried my luck. Upgraded to Reference and ticked Defective by Design setting, but it still won't work with either of my drives.
              I only found one other 20 bit CD in my collection and it plays/rips fine with normal settings.
              For my next drive, is there a particular spec I should look for?
                • 4015
                You do not have a 20-bit CD. You have standard audio CD, which is 16-bit. The 20-bit mastering refers to the technology used to create the stereo masters and not the CD.
                • musicmafia
                  • Jan 2008
                  • 51
                  Whatever it is I'd sure like to rip it
                    • 4015
                    Yes, sure.
                    I'm guessing the problem is related to the Track Zero (greyed out) hidden track you mentioned earlier in post no. 1
                      • 43930
                      You want to look for a drive which can overread in to the lead in / out.
                      • musicmafia
                        • Jan 2008
                        • 51
                        I googled those terms and didn't find any links to drives, only old discussions in various forums. Does anyone know where to find a list of these drives? Thanks, M
                        • c-eling
                          • Apr 2014
                          • 21
                          Good luck, it's a type of copy protection, my Peter Gabriel Up Promo has it also with the same symptoms, been trying for years with different software etc... gave up and did a analog out recording of it, cut and tag
                            • 43930
                            Many of the earlier plextors could, see:
                            • musicmafia
                              • Jan 2008
                              • 51
                              Thanks to everyone for weighing in. I ended up thinking of a totally old-school workaround and it actually worked.
                              I have an old stand alone Tascam CD recorder that I haven't used in ages. Since the disc played fine on CD players (just not in drives) I burned it from a CD player via digital optical cable into the CD recorder and then ripped the CD-R using CD ripper. Read all the data and tracks. Old school but it worked Thanks again.
