Uninstallation problem
    Hi, bit of a weird problem this one. I had installed dBpowerAMP to test out it's CD ripping features however when I went to uninstall it, the "Copy Music From CD Using dMC Audio CD Input" option remains whenever I auto-run a cd-rom.
    When I choose the option it searches for "CDGrab.exe", but of course it doesn't find it as dBpowerAMP has been uninstalled.
    Can anyone recommend a way to remove the option from the autorun options of Win XP? Thanks if anyone knows what I'm on about.
  • RossRoy
    • May 2003
    • 403
    Re: Uninstallation problem
    I know what you are talking about, but you would probably have better luck on www.tweakxp.com for that.
    Have a look through their optimisation pages, and if you don't find it there, you can ask on their forum.
      Thanks a lot, will do.
        • 43989
        I will note it as a bug.
