best settings for mpc
    hi
    can anyone tell me ..which is the best setting in dbpoweramp for extreme performance and quality for MPC Codec...SIZE DOES'NT MATTER..I Need The Best Quality as i have to make of my cd's...
    thanxxx
  • RossRoy
    • May 2003
    • 403
    Re: best settings for mpc
    If you want best quality and space is not a concern, why not go lossless with Monkey Audio or Flac? You won't have to concern yourself with settings, and you will have perfect quality for anything you may want to do with the audio.
      but still if i need
      to dat in mpc wat will b the settings ?
      • RossRoy
        • May 2003
        • 403
        From what I've read about Musepack (I've not tried it yet), I'd say go with standard or insane. Extreme is overkill and can actually create artifacts in the music.
        But standard should do the job more than adequatly.
