Problems Converting Apple Lossless to AAC
  • Gavin Blackett
    • Jan 2014
    • 25
    Hi
    I've been trying to create a low res version of my Apple lossless files in my iTunes library.
    I've successfully (I think) downloaded and installed the AAC codec - at least it's in the codec folder.
    When I set the batch converter off, it runs through the 12,000+ files pretty quickly, and creates the new files - all of which seems to be as I specify.
    The problem is that all the new files are 0 bytes big and with no metadata!
    What's going wrong?
    Gavin
    • 43928
    Re: Problems Converting Apple Lossless to AAC
    Try this AAC encoder, it is the one we switch over to:
    We will be phasing out the Nero encoder and replacing with this newer FDK version. Includes also a m4b encoder. <now released> Encoder.exe"]dBpoweramp-Codec-m4a FDK (AAC) Encoder[/URL] This install contains both 64 bit install (for dBpoweramp R15 beta 64 bit) and 32 bit install. By default the install will match
    • Gavin Blackett
      • Jan 2014
      • 25
      Thanks, Spoon. I'll give that a try this evening.
