Converting FLAC to mp3 problems.
  • jms209
    • Aug 2013
    So I used dbpoweramp to convert some FLACs to MP3.
    Well once it was done, all/most my tags where gone and didn't want to reapply the tags again.
    It was weird since some files had tags and some didn't.
    Checked tags with MP3Tag and the seemed good.
    I used foobar2000 and did the same thing,only this time the tags remained.
    I wanted to use 400 kbps,but foobar2000 does not support oever 320.
    Is anything over 320kbps overkill for mp3.Is it worth it?
    Should I just stick with 320 or FLAC?
    Also is what I experienced some sort of bug with dbpoweramp?
    • 43930
    Re: Converting FLAC to mp3 problems.
    Stick with 320 as many players cannot read above that.
    The flac files where the tags did not transfer, if you right click on a flac file >> edit id tags do tags show? if you right click on a problem mp3 >> edit id tags, do any tags show?
