Difference between Flac Compression 0 and Uncompressed
  • Corbatadog
    • Mar 2013
    • 30
    Hi all!
    This is my first time posting. Thanks for all of the advice!!
    Anyways, is there a difference between these two settings?
    Thanks!
    • 43928
    Re: Difference between Flac Compression 0 and Uncompressed
    Just file size and how the audio is stored, the decompressed result is identical between both.
    • Corbatadog
      • Mar 2013
      • 30
      So, if I am understanding correctly, compression Level 0 is still compressed a bit, while uncompressed just changes the file type but is still the same size as .wav.
      Thanks!
        • 43928
        Even uncompressed the audio is represented internally different to wave.
