How can I improve the speed of Asset UPnP
  • HighEnder
    • Mar 2012
    • 19
    Hi Spoon,
    maybe I have a luxury problem.
    I am using UPnP for at least 5 years. The organization of the files is unique.
    But there is one thing which should be improved.
    If a press the button "Refresh All" it takes quite a ages to reorganize the database.
    I changed the harddisk to a SSD and got some improvements.
    Is there a trick to speed up that process?
    My database contains 11.000 tracks, 680 albums, all FLAC - 311 GB
    The processor in the PC is a i7 2600K and I am using a Samsung SSD.
    Best regards
    Markus
    • 43930
    Re: How can I improve the speed of Asset UPnP
    A refresh all means the whole database is dropped, you should not have to do this without a reason.
    • HighEnder
      • Mar 2012
      • 19
      Hi Spoon,
      the reason is simple. If I rip another 20 CD's than it takes some time to get the information on the Linn Device via Kinsky.
      A refresh will update all information in total. However it takes some time.
      Therefore I asked if there is a possibiliy to increase this.
      Best regards
      Markus
        • 43930
        You need the Refresh (Detecting changes)
