QAAC CLI Encoder errors.
    • 43996
    Re: QAAC CLI Encoder errors.
    You would not have to make any changes, just point to the 64 bit exe.
    About speed, you would have to try to see.
    • Doug in Calgary
      • Apr 2012
      • 8
      What do I point to in the 64 bit folder.
      In the 64 bit folder:
      libsoxconvolver64.dll
      msvcp120.dll
      msvcr120.dll
      refalac64.exe
      In the 32 bit folder:
      libgcc_s_sjlj-1.dll
      libsoxconvolver.dll
      libsoxr.dll
      msvcp120.dll
      msvcr120.dll
      qaac.exe
      refalac.exe
      The 32 bit encoder script references qaac.exe. There is no qaac.exe in the 64 bit folder. I tried copying qaac.exe to the 32 bit folder and that didn't work. I also tried pointing to refalac64.exe in the 64 bit folder and that didn't work.
      Maybe the zip I downloaded is missing the 64 bit qaac.exe.
        • 43996
        You are missing the 64 bit qaac.exe
        • rudolffischer
          • Mar 2009
          • 24
          Hi all
          This thread seems to answer my question how to use qaac with dbpoweramp.
          I have taken tscolin's latest script from post *7 and put it and the x86 qaac files into the CLI encoder directory. When I try to batch convert, I get the stdIn Pipe error that tscolin mentioned in post *1.
          I have all the files from the qaac/x86 directory + encoder.txt in the CLI encoder directory.
          What could I be doing wrong?
          Thanks a lot
          • rudolffischer
            • Mar 2009
            • 24
            Solved
            Looking at other encoder.txt files, I figured out that there need to be quotes around [outfile] such as this "[outfile]"
            With this addition, the script in post *7 works
            • rudolffischer
              • Mar 2009
              • 24
              #21
              Here's the encoder.txt file as I am using it:
              - added quotes around [outfile]
              - added drop down to set target sample rate
              Code:
              Code:
              [codec].m4a
              qaac.exe
              [msgifnoencoder]
              Before using this encoder a seperate component must first be installed from [url]https://sites.google.com/site/qaacpage/[/url] .
              [radio&slider]
              4
              24
              292
              1
              10
              0
              Quality (tVBR)
              5
              Q4 (~40kbps)
              -V 4
              Q13 (~45kbps)
              -V 13
              Q22 (~75kbps)
              -V 22
              Q31 (~80kbps)
              -V 31
              Q40 (~95kbps)
              -V 40
              Q49 (~105kbps)
              -V 49
              Q58 (~115kbps)
              -V 58
              Q63 (~128kbps)
              -V 63
              Q68 (~135kbps)
              -V 68
              Q77 (~150kbps)
              -V 77
              Q86 (~165kbps)
              -V 86
              Q95 (~195kbps)
              -V 95
              Q104 (~225kbps)
              -V 104
              Q113 (~255kbps)
              -V 113
              Q122 (~285kbps)
              -V 122
              Q127 (~320kbps)
              -V 127
              Q0 (Highest Possible)
              -V 0
              [/sliderend]
              80
              0
              Bit Rate (ABR)
              9
              Average Bit Rate: 16 Kbps
              -a 16
              Average Bit Rate: 24 Kbps
              -a 24
              Average Bit Rate: 32 Kbps
              -a 32
              Average Bit Rate: 48 Kbps
              -a 48
              Average Bit Rate: 56 Kbps
              -a 56
              Average Bit Rate: 64 Kbps
              -a 64
              Average Bit Rate: 80 Kbps
              -a 80
              Average Bit Rate: 96 Kbps
              -a 96
              Average Bit Rate: 128 Kbps
              -a 128
              Average Bit Rate: 144 Kbps
              -a 144
              Average Bit Rate: 160 Kbps
              -a 160
              Average Bit Rate: 192 Kbps
              -a 192
              Average Bit Rate: 224 Kbps
              -a 224
              Average Bit Rate: 256 Kbps
              -a 256
              Average Bit Rate: 320 Kbps
              -a 320
              Average Bit Rate: Highest Possible
              -a 0
              [/sliderend]
              154
              0
              Bit Rate (cVBR)
              9
              Constrained Bit Rate: Auto
              -v 0
              Constrained Bit Rate: 16 Kbps
              -v 16
              Constrained Bit Rate: 24 Kbps
              -v 24
              Constrained Bit Rate: 32 Kbps
              -v 32
              Constrained Bit Rate: 48 Kbps
              -v 48
              Constrained Bit Rate: 56 Kbps
              -v 56
              Constrained Bit Rate: 64 Kbps
              -v 64
              Constrained Bit Rate: 80 Kbps
              -v 80
              Constrained Bit Rate: 96 Kbps
              -v 96
              Constrained Bit Rate: 128 Kbps
              -v 128
              Constrained Bit Rate: 144 Kbps
              -v 144
              Constrained Bit Rate: 160 Kbps
              -v 160
              Constrained Bit Rate: 192 Kbps
              -v 192
              Constrained Bit Rate: 224 Kbps
              -v 224
              Constrained Bit Rate: 256 Kbps
              -v 256
              Constrained Bit Rate: 320 Kbps
              -v 320
              Constrained Bit Rate: Highest Possible
              -v 0
              [/sliderend]
              218
              0
              Constant (CBR)
              Constant Bit Rate: 16 Kbps
              -c 16
              Constant Bit Rate: 24 Kbps
              -c 24
              Constant Bit Rate: 32 Kbps
              -c 32
              Constant Bit Rate: 48 Kbps
              -c 48
              Constant Bit Rate: 56 Kbps
              -c 56
              Constant Bit Rate: 64 Kbps
              -c 64
              Constant Bit Rate: 80 Kbps
              -c 80
              Constant Bit Rate: 96 Kbps
              -c 96
              Constant Bit Rate: 128 Kbps
              -c 128
              Constant Bit Rate: 144 Kbps
              -c 144
              Constant Bit Rate: 160 Kbps
              -c 160
              Constant Bit Rate: 192 Kbps
              -c 192
              Constant Bit Rate: 224 Kbps
              -c 224
              Constant Bit Rate: 256 Kbps
              -c 256
              Constant Bit Rate: 320 Kbps
              -c 320
              Constant Bit Rate: Highest Possible
              -c 0
              [/sliderend]
              [label]
              10
              44
              low quality (smaller file)
              808080
              [label]
              216
              44
              high quality (larger file)
              808080
              [combo]
              60
              66
              90
              1
              Force LC AAC
              Force HE AAC (< 84 kbps)
              --he
              [combo]
              160
              66
              90
              1
              Target Sample Rate
              TSR = auto
              --rate auto
              TSR = keep
              --rate keep
              TSR = 44.1kHz
              --rate 44100
              TSR = 48.0kHz
              --rate 48000
              [clistring]
              -o "[outfile]" --no-optimize -q2 -
              [minfreq]
              8000
              [maxfreq]
              96000
              [maxchannels]
              6
              • tscolin
                • Feb 2013
                • 10
                #22
                Thanks for the help and changes!
                I've made some simple formatting changes, moved things a smidge.
                Code:
                [codec]
                .m4a
                qaac.exe
                [msgifnoencoder]
                Before using this encoder a seperate component must first be installed from https://sites.google.com/site/qaacpage/ .
                [radio&slider]
                4
                24
                292
                1
                10
                0
                Quality (tVBR)
                5
                Q4 (~40kbps)
                -V 4
                Q13 (~45kbps)
                -V 13
                Q22 (~75kbps)
                -V 22
                Q31 (~80kbps)
                -V 31
                Q40 (~95kbps)
                -V 40
                Q49 (~105kbps)
                -V 49
                Q58 (~115kbps)
                -V 58
                Q63 (~128kbps)
                -V 63
                Q68 (~135kbps)
                -V 68
                Q77 (~150kbps)
                -V 77
                Q86 (~165kbps)
                -V 86
                Q95 (~195kbps)
                -V 95
                Q104 (~225kbps)
                -V 104
                Q113 (~255kbps)
                -V 113
                Q122 (~285kbps)
                -V 122
                Q127 (~320kbps)
                -V 127
                -V 0
                [/sliderend]
                80
                0
                Bit Rate (ABR)
                9
                -a 16
                -a 24
                -a 32
                -a 48
                -a 56
                -a 64
                -a 80
                -a 96
                -a 128
                -a 144
                -a 160
                -a 192
                -a 224
                -a 256
                -a 320
                -a 0
                [/sliderend]
                154
                0
                Bit Rate (cVBR)
                9
                -v 0
                -v 16
                -v 24
                -v 32
                -v 48
                -v 56
                -v 64
                -v 80
                -v 96
                -v 128
                -v 144
                -v 160
                -v 192
                -v 224
                -v 256
                -v 320
                -v 0
                [/sliderend]
                220
                0
                Constant (CBR)
                5
                -c 16
                -c 24
                -c 32
                -c 48
                -c 56
                -c 64
                -c 80
                -c 96
                -c 128
                -c 144
                -c 160
                -c 192
                -c 224
                -c 256
                -c 320
                -c 0
                [/sliderend]
                [label]
                10
                44
                808080
                [label]
                216
                44
                808080
                [combo]
                60
                66
                90
                1
                Force LC AAC
                --he
                [combo]
                160
                66
                90
                1
                Target Sample Rate
                TSR = auto
                --rate auto
                TSR = keep
                --rate keep
                TSR = 44.1kHz
                --rate 44100
                TSR = 48.0kHz
                --rate 48000
                [clistring]
                [minfreq]
                8000
                [maxfreq]
                96000
                [maxchannels]
                6
                Thank you for all the support guys! I'm really happy to see other people using this! QAAC is still my preferred AAC encoder. I still believe (read: my opinion) Apple's AAC encoder to be superior to FDK, FAAC, or nero (especially nero, its ancient).
                • Doug in Calgary
                  • Apr 2012
                  • 8
                  #23
                  I had Batch Converter working perfectly on a different computer. Now I'm struggling to get it to work on a new PC. I'm using Reference 15.1 and the latest QACC.exe along with the most recent version of the script (copied from thread directly above). I am getting the dreaded "Error writing audio data to StdIn Pipe [clEncoder::EncodeBlock]". I can use the LAME MP3 with the same Output File locations, so file permissions are likely not the issue. Any suggestions?
                  • Doug in Calgary
                    • Apr 2012
                    • 8
                    #24
                    This works on the other PC:
                    Code:
                    [codec]
                    .m4a
                    qaac.exe
                    [msgifnoencoder]
                    [radio&slider]
                    4
                    24
                    292
                    1
                    10
                    0
                    Quality (tVBR)
                    5
                    Q4 (~40kbps)
                    -V 4
                    Q13 (~45kbps)
                    -V 13
                    Q22 (~75kbps)
                    -V 22
                    Q31 (~80kbps)
                    -V 31
                    Q40 (~95kbps)
                    -V 40
                    Q49 (~105kbps)
                    -V 49
                    Q58 (~115kbps)
                    -V 58
                    Q63 (~128kbps)
                    -V 63
                    Q68 (~135kbps)
                    -V 68
                    Q77 (~150kbps)
                    -V 77
                    Q86 (~165kbps)
                    -V 86
                    Q98 (~195kbps)
                    -V 98
                    Q104 (~225kbps)
                    -V 104
                    Q113 (~255kbps)
                    -V 113
                    Q122 (~285kbps)
                    -V 122
                    Q127 (~320kbps)
                    -V 127
                    -V 0
                    [/sliderend]
                    80
                    0
                    Bit Rate (ABR)
                    9
                    -a 16
                    -a 24
                    -a 32
                    -a 48
                    -a 56
                    -a 64
                    -a 80
                    -a 96
                    -a 128
                    -a 144
                    -a 160
                    -a 192
                    -a 224
                    -a 256
                    -a 320
                    -a 0
                    [/sliderend]
                    154
                    0
                    Bit Rate (cVBR)
                    9
                    -v 0
                    -v 16
                    -v 24
                    -v 32
                    -v 48
                    -v 56
                    -v 64
                    -v 80
                    -v 96
                    -v 128
                    -v 144
                    -v 160
                    -v 192
                    -v 224
                    -v 256
                    -v 320
                    -v 0
                    [/sliderend]
                    218
                    0
                    Constant (CBR)
                    -c 16
                    -c 24
                    -c 32
                    -c 48
                    -c 56
                    -c 64
                    -c 80
                    -c 96
                    -c 128
                    -c 144
                    -c 160
                    -c 192
                    -c 224
                    -c 256
                    -c 320
                    -c 0
                    [/sliderend]
                    [label]
                    10
                    44
                    808080
                    [label]
                    216
                    44
                    808080
                    [combo]
                    60
                    66
                    80
                    1
                    Force LC AAC
                    --he
                    [clistring]
                    -o [outfile] --no-optimize -q2 -
                    [minfreq]
                    8000
                    [maxfreq]
                    96000
                    [maxchannels]
                    6
                    Whether or not I use quotes around [outfile] doesn't seem to matter
                    • tscolin
                      • Feb 2013
                      • 10
                      #25
                      Make sure you have all the prerequisite libraries. For instance, install iTunes if you haven't already, and QuickTime if that doesn't fix it.
                      • Doug in Calgary
                        • Apr 2012
                        • 8
                        #26
                        D'Oh. I had the PC plugged in but I didn't have iTunes installed. Thanks and the latest script works great!
                        • JII
                          • Mar 2015
                          • 18
                          #27
                          Hi everybody.
                          Thank's a lot for this code, very useful to remplace m4a FDK AAC Encoder (that's seemed a good idea but it has hardware compatibility issues even in LC CBR).
                          However, it doesn't work with QAAC x64 version. No problem with x86 version (which is 33% faster than FDK AAC by me).
                          If someone has an idea to solve that. Thank you.
                          • JII
                            • Mar 2015
                            • 18
                            #28
                            Originally posted by JII
                            Hi everybody.
                            "Edit" : It seems that QAAC has the same hardware compatibility issue...so it must be a software compatibility issue of the hardware
                            Ok it's 4 years old but it doesn't seem a good reason to me. Finally the "old" good Nero AAC encoder is still very useful... Too bad it doesn't work with x64 dbPoweramp. I'll try with CLI encoder.
                            I'm still interested by the mean to use x64 QAAC with CLI Encoder.
                            • AndersHu
                              • Apr 2008
                              • 28
                              #29
                              I have no trouble using the 64-bit version.
                              I have installed iTunes 12.1.1.4 64-bit, and copied the content of qaac_2.47/x64 into the dBpoweramp/encoder/CLI Encoder.
                              My encoder.txt looks like this:
                              Code:
                              [codec]
                              .m4a
                              qaac64.exe
                              [msgifnoencoder]
                              [radio&slider]
                              4
                              24
                              292
                              1
                              10
                              0
                              Quality (tVBR)
                              9
                              Q0 (~40kbps)
                              --tvbr 0
                              Q9 (~45kbps)
                              --tvbr 9
                              Q18 (~75kbps)
                              --tvbr 18
                              Q27 (~80kbps)
                              --tvbr 27
                              Q36 (~95kbps)
                              --tvbr 36
                              Q45 (~105kbps)
                              --tvbr 45
                              Q54 (~115kbps)
                              --tvbr 54
                              Q64 (~135kbps)
                              --tvbr 64
                              Q73 (~150kbps)
                              --tvbr 73
                              Q82 (~165kbps)
                              --tvbr 82
                              Q91 (~195kbps)
                              --tvbr 91
                              Q100 (~225kbps)
                              --tvbr 100
                              Q109 (~255kbps)
                              --tvbr 109
                              Q118 (~285kbps)
                              --tvbr 118
                              Q127 (~320kbps)
                              --tvbr 127
                              [/sliderend]
                              80
                              0
                              Bit Rate (ABR)
                              9
                              -a 16
                              -a 24
                              -a 32
                              -a 48
                              -a 56
                              -a 64
                              -a 80
                              -a 96
                              -a 128
                              -a 144
                              -a 160
                              -a 192
                              -a 224
                              -a 256
                              -a 320
                              -a 0
                              [/sliderend]
                              154
                              0
                              Bit Rate (cVBR)
                              9
                              -v 0
                              -v 16
                              -v 24
                              -v 32
                              -v 48
                              -v 56
                              -v 64
                              -v 80
                              -v 96
                              -v 128
                              -v 144
                              -v 160
                              -v 192
                              -v 224
                              -v 256
                              -v 320
                              -v 0
                              [/sliderend]
                              218
                              0
                              Constant (CBR)
                              -c 16
                              -c 24
                              -c 32
                              -c 48
                              -c 56
                              -c 64
                              -c 80
                              -c 96
                              -c 128
                              -c 144
                              -c 160
                              -c 192
                              -c 224
                              -c 256
                              -c 320
                              -c 0
                              [/sliderend]
                              [label]
                              10
                              44
                              808080
                              [label]
                              216
                              44
                              808080
                              [combo]
                              60
                              66
                              80
                              1
                              Force LC AAC
                              --he
                              [clistring]
                              [minfreq]
                              8000
                              [maxfreq]
                              96000
                              [maxchannels]
                              6
                              • JII
                                • Mar 2015
                                • 18
                                #30
                                Thank you for your encoder.txt wich is a little different that Doug in Calgary's (tVBR commands are not the same and yours don't have Target Sample Rate option; why this differences ?). However, it doesn't work either ("Error wrinting audio data to StdIn Pipe [clEncoder::EncoderBlock]).
                                I'm using qaac 2.47 too but only the last AppleApplicationSupport.msi included in latest Quicktime archive (and in Itunes archive) as explained at https://sites.google.com/site/qaacpage/. I don't really want Quicktime or Itunes (especially Itunes) on my PC, and it works for 32 bit version, so it should with 64...
