Couple of quick questions please
    • 43930
    Re: Couple of quick questions please
    crcv2 did not even exist in the referenced post, it was added later. Having different results for CRCv1 and CRCv2 is not a bug, it is not an issue.
    • Gbeer7
      • Mar 2011
      • 165
      So simply, what is the differance with my tips with the 84 and 2 and the other guys ? Think I'm getting myself in a muddle over all this. Do you remember my older post ?
        • 5744
        you can see all of your old posts by simply clicking on your username. It will take you here:
        • eaglescout1998
          • Apr 2009
          • 196
          I can see it was a mistake to link to the Hydrogenaudio site. I apologize for that. It was a brain fart of epic proportions.
          AccurateRip is, in nearly all cases, a sound indicator that your rip is accurate. However, because the database is built on user submissions, there is always the chance that someone might submit a bad rip. This isn't a bug; it's just the nature of a user-submitted database. As more people submit to the database, these bad rips become less of a problem (assuming they're not purged from it).
          Regardless, this is where the confidence number comes into play. It helps you guage the accuracy of the rip; the more people that agree with your rip, the better. In your case, 200 other people ripped the exact same CD and got the exact same result as you. If that isn't assurance, I don't know what is.
          If something looks fishy, you can always re-rip the track(s) using a second CD drive. If the CRC(s) turn green, then the two rips are identical. If they turn red, then you might have a problem. But don't stress yourself over what might happen down the road.
          • Gbeer7
            • Mar 2011
            • 165
            Hi eaglescout1998. Sorry, i suffer from OCD and latch onto anything. I was a little concerned reading your post as i had a CD with had most accurate rips as 84 and a couple with 2. My mind put 2 and 2 together and panicked ! I have an issue with perfection that i'm working on, so apologies for annoying or frustrating anyone.
            Spoon, I have run PerfectTunes on my Beatles Capital albums (Ones with mostly 84 but with a few with 2), and it reported back accurate. It just had next to the album, "x number of tracks accurate". If there was an inaccurate track would it say it next to the other accurate result ? OR would i have to compare album tracks to the result of accurate tracks reported by PerfectTunes and find the faulty track ?
            Finally, if PerfectTunes says the track is accurate is that as good as perfect ? (or only depending on how many people's rips its compared with or the fact perfectTunes is still in Beta?)
            Why doesn't perfectTunes report back saying "accurate with x amount of people" or is this not necessary ?
            I have read your blurb on PerfectTunes, but just want to get a better understanding.
            Thank you for your patience spoon, i know i have a tendency to worry.
              • 43930
              #21
              If you had ripping errors the albums would be show separately.
              You can click the 'i' match information button for details of confidence.
              • Porcus
                • Feb 2007
                • 792
                #22
                There are cases where a CD drive brand/model makes consistent errors, and unless/until Spoon excludes the submissions from those drives from the database, people who have one such drive, might get false verifications. But they are rare -- and even less likely as a score of 200 is reported (then there would have to be many having those few drives).
                eaglescout1998's suggestion of ripping a second time with a different drive (i.e. different brand/model) will resolve that worry. You don't need to do so for every CD (if they read one CD the same, then they should read every CDs the same). If you don't have access to a 2nd drive on your computer, try another one (you can even use the free dBpoweramp version) and write down the CRCs and compare to the ones in your log file for that CD. Use a CD which went through without re-ripping on your 'Secure' setup.
                If two different CD drives give the same result, then the chance that both have a very rare disease, is small.
                And, there is nothing wrong about a CRC with only numbers, no letters. About 1 of 43 will be be 'letterless', and you have ripped many times 43 tracks
                Feels better now?
                • Gbeer7
                  • Mar 2011
                  • 165
                  #23
                  Porcus, would using PerfectTunes be just as good as reripping ?
                  This is my issue,
                  • Porcus
                    • Feb 2007
                    • 792
                    #24
                    If you want to failsafe yourself against having one of these strange drives that produces consistent errors, then PerfectTUNES won't help (at least not as of now).
                    PerfectTUNES might help if you ripped at a time where the disc in question, was not in the database. If someone subsequently submitted them, you might use PerfectTUNES to look up. (Myself, I have 2500 CDs which were upon time of ripping not present in the database, so I will have a verification job to do when PerfectTUNES is finalised.)
                    The 84 and 2 I think have been up in other threads?
                    • Gbeer7
                      • Mar 2011
                      • 165
                      #25
                      Hi porcus, it was discussed in a previous thread and spoon said the "2" result was looking at the crcv1 area. But in light of what was rasied in this thread earlier, both examples seemed similar and I was concerned these were bad rips as well. Not sure the differance with my issue and the other chaps.
                      • Gbeer7
                        • Mar 2011
                        • 165
                        #26
                        I've used Perfect Tunes all my Beatles capital albums, does this look ok ?
                        Beatles, The - The Capitol Albums, Vol. 1, Disc 2
                        Track 1: AccurateRip Verified Confidence 9, Pressing Offset +0 [ARv2 CRC 272C058D] Z:\Beatles, The\The Capitol Albums, Vol. 1, Disc 2\01 Beatles, The - Roll Over
                        Beethoven.flac
                        Track 2: AccurateRip Verified Confidence 9, Pressing Offset +0 [ARv2 CRC FB9BBD86] Z:\Beatles, The\The Capitol Albums, Vol. 1, Disc 2\02 Beatles, The - Thank You
                        Girl.flac
                        Track 3: AccurateRip Verified Confidence 9, Pressing Offset +0 [ARv2 CRC D5EE1BA8] Z:\Beatles, The\The Capitol Albums, Vol. 1, Disc 2\03 Beatles, The - You Really
                        Got a Hold on Me.flac
                        Track 4: AccurateRip Verified Confidence 8, Pressing Offset +0 [ARv2 CRC 67CC8A09] Z:\Beatles, The\The Capitol Albums, Vol. 1, Disc 2\04 Beatles, The - Devil in Her
                        Heart.flac
                        Track 5: AccurateRip Verified Confidence 8, Pressing Offset +0 [ARv2 CRC 6F9449A2] Z:\Beatles, The\The Capitol Albums, Vol. 1, Disc 2\05 Beatles, The - Money.flac
                        Track 6: AccurateRip Verified Confidence 9, Pressing Offset +0 [ARv2 CRC AD2C83AF] Z:\Beatles, The\The Capitol Albums, Vol. 1, Disc 2\06 Beatles, The - You Can't Do
                        That.flac
                        Track 7: AccurateRip Verified Confidence 9, Pressing Offset +0 [ARv2 CRC 66993873] Z:\Beatles, The\The Capitol Albums, Vol. 1, Disc 2\07 Beatles, The - Long Tall
                        Sally.flac
                        Track 8: AccurateRip Verified Confidence 9, Pressing Offset +0 [ARv2 CRC A01EACBE] Z:\Beatles, The\The Capitol Albums, Vol. 1, Disc 2\08 Beatles, The - I Call Your
                        Name.flac
                        Track 9: AccurateRip Verified Confidence 9, Pressing Offset +0 [ARv2 CRC 4FB50383] Z:\Beatles, The\The Capitol Albums, Vol. 1, Disc 2\09 Beatles, The - Please Mr.
                        Postman.flac
                        Track 10: AccurateRip Verified Confidence 9, Pressing Offset +0 [ARv2 CRC 73497C60] Z:\Beatles, The\The Capitol Albums, Vol. 1, Disc 2\10 Beatles, The - I'll Get
                        You.flac
                        Track 11: AccurateRip Verified Confidence 9, Pressing Offset +0 [ARv2 CRC 873DD422] Z:\Beatles, The\The Capitol Albums, Vol. 1, Disc 2\11 Beatles, The - She Loves
                        You.flac
                        Track 12: AccurateRip Verified Confidence 8, Pressing Offset +0 [ARv2 CRC 9AE73F69] Z:\Beatles, The\The Capitol Albums, Vol. 1, Disc 2\12 Beatles, The - Roll Over
                        Beethoven (Mono).flac
                        Track 13: AccurateRip Verified Confidence 9, Pressing Offset +0 [ARv2 CRC 85AC2396] Z:\Beatles, The\The Capitol Albums, Vol. 1, Disc 2\13 Beatles, The - Thank You
                        Girl (Mono).flac
                        Track 14: AccurateRip Verified Confidence 9, Pressing Offset +0 [ARv2 CRC 2A41A776] Z:\Beatles, The\The Capitol Albums, Vol. 1, Disc 2\14 Beatles, The - You Really
                        Got A Hold On Me (Mono).flac
                        Track 15: AccurateRip Verified Confidence 9, Pressing Offset +0 [ARv2 CRC 3BCEDE76] Z:\Beatles, The\The Capitol Albums, Vol. 1, Disc 2\15 Beatles, The - Devil In
                        Her Heart (Mono).flac
                        Track 16: AccurateRip Verified Confidence 9, Pressing Offset +0 [ARv2 CRC 2178FE09] Z:\Beatles, The\The Capitol Albums, Vol. 1, Disc 2\16 Beatles, The - Money
                        (Mono).flac
                        Track 17: AccurateRip Verified Confidence 9, Pressing Offset +0 [ARv2 CRC 79FD2B4F] Z:\Beatles, The\The Capitol Albums, Vol. 1, Disc 2\17 Beatles, The - You Can't
                        Do That (Mono).flac
                        Track 18: AccurateRip Verified Confidence 9, Pressing Offset +0 [ARv2 CRC C638BE20] Z:\Beatles, The\The Capitol Albums, Vol. 1, Disc 2\18 Beatles, The - Long Tall
                        Sally (Mono).flac
                        Track 19: AccurateRip Verified Confidence 9, Pressing Offset +0 [ARv2 CRC 84F9C1E2] Z:\Beatles, The\The Capitol Albums, Vol. 1, Disc 2\19 Beatles, The - I Call Your
                        Name (Mono).flac
                        Track 20: AccurateRip Verified Confidence 9, Pressing Offset +0 [ARv2 CRC E1BD3184] Z:\Beatles, The\The Capitol Albums, Vol. 1, Disc 2\20 Beatles, The - Please Mr.
                        Postman (Mono).flac
                        Track 21: AccurateRip Verified Confidence 8, Pressing Offset +0 [ARv2 CRC 812756AE] Z:\Beatles, The\The Capitol Albums, Vol. 1, Disc 2\21 Beatles, The - I'll Get
                        You (Mono).flac
                        Track 22: AccurateRip Verified Confidence 9, Pressing Offset +0 [ARv2 CRC 603816C1] Z:\Beatles, The\The Capitol Albums, Vol. 1, Disc 2\22 Beatles, The - She Loves
                        You (Mono).flac
                        Beatles, The - The Capitol Albums, Vol. 1, Disc 3
                        Track 1: AccurateRip Verified Confidence 9, Pressing Offset +0 [ARv2 CRC 4AD3B84C] Z:\Beatles, The\The Capitol Albums, Vol. 1, Disc 3\01 Beatles, The - I'll Cry
                        Instead.flac
                        Track 2: AccurateRip Verified Confidence 9, Pressing Offset +0 [ARv2 CRC 62199C18] Z:\Beatles, The\The Capitol Albums, Vol. 1, Disc 3\02 Beatles, The - Things We
                        Said Today.flac
                        Track 3: AccurateRip Verified Confidence 8, Pressing Offset +0 [ARv2 CRC 10A51F3E] Z:\Beatles, The\The Capitol Albums, Vol. 1, Disc 3\03 Beatles, The - Anytime At
                        All.flac
                        Track 4: AccurateRip Verified Confidence 8, Pressing Offset +0 [ARv2 CRC 8B1B0924] Z:\Beatles, The\The Capitol Albums, Vol. 1, Disc 3\04 Beatles, The - When I Get
                        Home.flac
                        Track 5: AccurateRip Verified Confidence 9, Pressing Offset +0 [ARv2 CRC B8EDA1F8] Z:\Beatles, The\The Capitol Albums, Vol. 1, Disc 3\05 Beatles, The - Slow
                        Down.flac
                        Track 6: AccurateRip Verified Confidence 9, Pressing Offset +0 [ARv2 CRC 8EF2F3C1] Z:\Beatles, The\The Capitol Albums, Vol. 1, Disc 3\06 Beatles, The -
                        Matchbox.flac
                        Track 7: AccurateRip Verified Confidence 9, Pressing Offset +0 [ARv2 CRC 97B2EBBC] Z:\Beatles, The\The Capitol Albums, Vol. 1, Disc 3\07 Beatles, The - Tell Me
                        Why.flac
                        Track 8: AccurateRip Verified Confidence 9, Pressing Offset +0 [ARv2 CRC ACBDA7CF] Z:\Beatles, The\The Capitol Albums, Vol. 1, Disc 3\08 Beatles, The - And I Love
                        Her.flac
                        Track 9: AccurateRip Verified Confidence 9, Pressing Offset +0 [ARv2 CRC 600361CD] Z:\Beatles, The\The Capitol Albums, Vol. 1, Disc 3\09 Beatles, The - I'm Happy
                        Just to Dance With You.flac
                        Track 10: AccurateRip Verified Confidence 9, Pressing Offset +0 [ARv2 CRC BDD1128C] Z:\Beatles, The\The Capitol Albums, Vol. 1, Disc 3\10 Beatles, The - If I
                        Fell.flac
                        Track 11: AccurateRip Verified Confidence 8, Pressing Offset +0 [ARv2 CRC 75A61024] Z:\Beatles, The\The Capitol Albums, Vol. 1, Disc 3\11 Beatles, The - Komm, Gib
                        Mir Deine Hand (I Want to Hold Your Hand).flac
                        Track 12: AccurateRip Verified Confidence 9, Pressing Offset +0 [ARv2 CRC FCEB171E] Z:\Beatles, The\The Capitol Albums, Vol. 1, Disc 3\12 Beatles, The - I'll Cry
                        Instead (Mono).flac
                        Track 13: AccurateRip Verified Confidence 9, Pressing Offset +0 [ARv2 CRC C3C670C6] Z:\Beatles, The\The Capitol Albums, Vol. 1, Disc 3\13 Beatles, The - Things We
                        Said Today (Mono).flac
                        Track 14: AccurateRip Verified Confidence 9, Pressing Offset +0 [ARv2 CRC A2161FBF] Z:\Beatles, The\The Capitol Albums, Vol. 1, Disc 3\14 Beatles, The - Anytime At
                        All (Mono).flac
                        Track 15: AccurateRip Verified Confidence 9, Pressing Offset +0 [ARv2 CRC 4D189E02] Z:\Beatles, The\The Capitol Albums, Vol. 1, Disc 3\15 Beatles, The - When I Get
                        Home (Mono).flac
                        Track 16: AccurateRip Verified Confidence 9, Pressing Offset +0 [ARv2 CRC 1E90DE64] Z:\Beatles, The\The Capitol Albums, Vol. 1, Disc 3\16 Beatles, The - Slow Down
                        (Mono).flac
                        Track 17: AccurateRip Verified Confidence 9, Pressing Offset +0 [ARv2 CRC D5E949A4] Z:\Beatles, The\The Capitol Albums, Vol. 1, Disc 3\17 Beatles, The - Matchbox
                        (Mono).flac
                        Track 18: AccurateRip Verified Confidence 9, Pressing Offset +0 [ARv2 CRC 93B56751] Z:\Beatles, The\The Capitol Albums, Vol. 1, Disc 3\18 Beatles, The - Tell Me Why
                        (Mono).flac
                        Track 19: AccurateRip Verified Confidence 9, Pressing Offset +0 [ARv2 CRC FEB122C4] Z:\Beatles, The\The Capitol Albums, Vol. 1, Disc 3\19 Beatles, The - And I Love
                        Her (Mono).flac
                        Track 20: AccurateRip Verified Confidence 9, Pressing Offset +0 [ARv2 CRC 80756655] Z:\Beatles, The\The Capitol Albums, Vol. 1, Disc 3\20 Beatles, The - I'm Happy
                        Just To Dance With You (Mono).flac
                        Track 21: AccurateRip Verified Confidence 9, Pressing Offset +0 [ARv2 CRC 9A3371AB] Z:\Beatles, The\The Capitol Albums, Vol. 1, Disc 3\21 Beatles, The - If I Fell
                        (Mono).flac
                        Track 22: AccurateRip Verified Confidence 9, Pressing Offset +0 [ARv2 CRC 991845C5] Z:\Beatles, The\The Capitol Albums, Vol. 1, Disc 3\22 Beatles, The - Komm, Gib
                        Mir Deine Hand (I Want To Hold Your Hand) (Mono).flac
                        Beatles, The - The Capitol Albums, Vol. 1, Disc 4
                        Track 1: AccurateRip Verified Confidence 13, Pressing Offset +0 [ARv1 CRC 8A781854] Z:\Beatles, The\The Capitol Albums, Vol. 1, Disc 4\01 Beatles, The - No
                        Reply.flac
                        Track 2: AccurateRip Verified Confidence 14, Pressing Offset +0 [ARv1 CRC 1CAE2BA3] Z:\Beatles, The\The Capitol Albums, Vol. 1, Disc 4\02 Beatles, The - I'm a
                        Loser.flac
                        Track 3: AccurateRip Verified Confidence 13, Pressing Offset +0 [ARv1 CRC 0E1C86CC] Z:\Beatles, The\The Capitol Albums, Vol. 1, Disc 4\03 Beatles, The - Baby's in
                        Black.flac
                        Track 4: AccurateRip Verified Confidence 14, Pressing Offset +0 [ARv1 CRC 150B30F4] Z:\Beatles, The\The Capitol Albums, Vol. 1, Disc 4\04 Beatles, The - Rock And
                        Roll Music.flac
                        Track 5: AccurateRip Verified Confidence 13, Pressing Offset +0 [ARv1 CRC 423A4C8B] Z:\Beatles, The\The Capitol Albums, Vol. 1, Disc 4\05 Beatles, The - I'll Follow
                        the Sun.flac
                        Track 6: AccurateRip Verified Confidence 11, Pressing Offset +0 [ARv1 CRC F611C71E] Z:\Beatles, The\The Capitol Albums, Vol. 1, Disc 4\06 Beatles, The - Mr.
                        Moonlight.flac
                        Track 7: AccurateRip Verified Confidence 13, Pressing Offset +0 [ARv1 CRC 8F78CB12] Z:\Beatles, The\The Capitol Albums, Vol. 1, Disc 4\07 Beatles, The - Honey
                        Don't.flac
                        Track 8: AccurateRip Verified Confidence 12, Pressing Offset +0 [ARv1 CRC 1716D034] Z:\Beatles, The\The Capitol Albums, Vol. 1, Disc 4\08 Beatles, The - I'll Be
                        Back.flac
                        Track 9: AccurateRip Verified Confidence 13, Pressing Offset +0 [ARv1 CRC 2173AED6] Z:\Beatles, The\The Capitol Albums, Vol. 1, Disc 4\09 Beatles, The - She's a
                        Woman.flac
                        Track 10: AccurateRip Verified Confidence 13, Pressing Offset +0 [ARv1 CRC 3F486800] Z:\Beatles, The\The Capitol Albums, Vol. 1, Disc 4\10 Beatles, The - I Feel
                        Fine.flac
                        Track 11: AccurateRip Verified Confidence 14, Pressing Offset +0 [ARv1 CRC 8B179660] Z:\Beatles, The\The Capitol Albums, Vol. 1, Disc 4\11 Beatles, The -
                        Everybody's Trying to Be My Baby.flac
                        Track 12: AccurateRip Verified Confidence 15, Pressing Offset +0 [ARv1 CRC 55510BAB] Z:\Beatles, The\The Capitol Albums, Vol. 1, Disc 4\12 Beatles, The - No Reply
                        (Mono).flac
                        Track 13: AccurateRip Verified Confidence 14, Pressing Offset +0 [ARv1 CRC EB85EC8B] Z:\Beatles, The\The Capitol Albums, Vol. 1, Disc 4\13 Beatles, The - I'm A
                        Loser (Mono).flac
                        Track 14: AccurateRip Verified Confidence 14, Pressing Offset +0 [ARv1 CRC 24DEB2E8] Z:\Beatles, The\The Capitol Albums, Vol. 1, Disc 4\14 Beatles, The - Baby's In
                        Black (Mono).flac
                        Track 15: AccurateRip Verified Confidence 15, Pressing Offset +0 [ARv1 CRC CCA4B0B3] Z:\Beatles, The\The Capitol Albums, Vol. 1, Disc 4\15 Beatles, The - Rock And
                        Roll Music (Mono).flac
                        Track 16: AccurateRip Verified Confidence 16, Pressing Offset +0 [ARv1 CRC A3EEFB80] Z:\Beatles, The\The Capitol Albums, Vol. 1, Disc 4\16 Beatles, The - I'll
                        Follow The Sun (Mono).flac
                        Track 17: AccurateRip Verified Confidence 14, Pressing Offset +0 [ARv1 CRC B1A49990] Z:\Beatles, The\The Capitol Albums, Vol. 1, Disc 4\17 Beatles, The - Mr.
                        Moonlight (Mono).flac
                        Track 18: AccurateRip Verified Confidence 14, Pressing Offset +0 [ARv1 CRC 971A316E] Z:\Beatles, The\The Capitol Albums, Vol. 1, Disc 4\18 Beatles, The - Honey
                        Don't (Mono).flac
                        Track 19: AccurateRip Verified Confidence 15, Pressing Offset +0 [ARv1 CRC 0BC97E08] Z:\Beatles, The\The Capitol Albums, Vol. 1, Disc 4\19 Beatles, The - I'll Be
                        Back (Mono).flac
                        Track 20: AccurateRip Verified Confidence 13, Pressing Offset +0 [ARv1 CRC 67515413] Z:\Beatles, The\The Capitol Albums, Vol. 1, Disc 4\20 Beatles, The - She's A
                        Woman (Mono).flac
                        Track 21: AccurateRip Verified Confidence 16, Pressing Offset +0 [ARv1 CRC 4BD88385] Z:\Beatles, The\The Capitol Albums, Vol. 1, Disc 4\21 Beatles, The - I Feel
                        Fine (Mono).flac
                        Track 22: AccurateRip Verified Confidence 17, Pressing Offset +0 [ARv1 CRC 6C39842A] Z:\Beatles, The\The Capitol Albums, Vol. 1, Disc 4\22 Beatles, The -
                        Everybody's Trying To Be My Baby (Mono).flac
                        Beatles, The - The Capitol Albums, Vol. 1, Meet The Beatles!
                        Track 1: AccurateRip Verified Confidence 10, Pressing Offset +0 [ARv2 CRC F3B21C61] Z:\Beatles, The\The Capitol Albums, Vol. 1, Meet the Beatles!\01 Beatles, The -
                        I Want to Hold Your Hand.flac
                        Track 2: AccurateRip Verified Confidence 11, Pressing Offset +0 [ARv2 CRC 20A98CBD] Z:\Beatles, The\The Capitol Albums, Vol. 1, Meet the Beatles!\02 Beatles, The -
                        I Saw Her Standing There.flac
                        Track 3: AccurateRip Verified Confidence 11, Pressing Offset +0 [ARv2 CRC 1E246F33] Z:\Beatles, The\The Capitol Albums, Vol. 1, Meet the Beatles!\03 Beatles, The -
                        This Boy.flac
                        Track 4: AccurateRip Verified Confidence 11, Pressing Offset +0 [ARv2 CRC FDE1B59C] Z:\Beatles, The\The Capitol Albums, Vol. 1, Meet the Beatles!\04 Beatles, The -
                        It Won't Be Long.flac
                        Track 5: AccurateRip Verified Confidence 10, Pressing Offset +0 [ARv2 CRC C29B327C] Z:\Beatles, The\The Capitol Albums, Vol. 1, Meet the Beatles!\05 Beatles, The -
                        All I've Got to Do.flac
                        Track 6: AccurateRip Verified Confidence 10, Pressing Offset +0 [ARv2 CRC 2FF0EBFE] Z:\Beatles, The\The Capitol Albums, Vol. 1, Meet the Beatles!\06 Beatles, The -
                        All My Loving.flac
                        Track 7: AccurateRip Verified Confidence 9, Pressing Offset +0 [ARv2 CRC ACD94CD1] Z:\Beatles, The\The Capitol Albums, Vol. 1, Meet the Beatles!\07 Beatles, The -
                        Don't Bother Me.flac
                        Track 8: AccurateRip Verified Confidence 10, Pressing Offset +0 [ARv2 CRC FCC342CB] Z:\Beatles, The\The Capitol Albums, Vol. 1, Meet the Beatles!\08 Beatles, The -
                        Little Child.flac
                        Track 9: AccurateRip Verified Confidence 10, Pressing Offset +0 [ARv2 CRC 8645CC94] Z:\Beatles, The\The Capitol Albums, Vol. 1, Meet the Beatles!\09 Beatles, The -
                        Till There Was You.flac
                        Track 10: AccurateRip Verified Confidence 10, Pressing Offset +0 [ARv2 CRC 9459EA29] Z:\Beatles, The\The Capitol Albums, Vol. 1, Meet the Beatles!\10 Beatles, The -
                        Hold Me Tight.flac
                        Track 11: AccurateRip Verified Confidence 10, Pressing Offset +0 [ARv2 CRC 3797A222] Z:\Beatles, The\The Capitol Albums, Vol. 1, Meet the Beatles!\11 Beatles, The -
                        I Wanna Be Your Man.flac
                        Track 12: AccurateRip Verified Confidence 10, Pressing Offset +0 [ARv2 CRC 0EB94B65] Z:\Beatles, The\The Capitol Albums, Vol. 1, Meet the Beatles!\12 Beatles, The -
                        Not a Second Time.flac
                        Track 13: AccurateRip Verified Confidence 10, Pressing Offset +0 [ARv2 CRC D5AD8BA3] Z:\Beatles, The\The Capitol Albums, Vol. 1, Meet the Beatles!\13 Beatles, The -
                        I Want To Hold Your Hand (Mono).flac
                        Track 14: AccurateRip Verified Confidence 10, Pressing Offset +0 [ARv2 CRC BC867B9D] Z:\Beatles, The\The Capitol Albums, Vol. 1, Meet the Beatles!\14 Beatles, The -
                        I Saw Her Standing There (Mono).flac
                        Track 15: AccurateRip Verified Confidence 10, Pressing Offset +0 [ARv2 CRC BDE38704] Z:\Beatles, The\The Capitol Albums, Vol. 1, Meet the Beatles!\15 Beatles, The -
                        This Boy (Mono).flac
                        Track 16: AccurateRip Verified Confidence 9, Pressing Offset +0 [ARv2 CRC 545B29E6] Z:\Beatles, The\The Capitol Albums, Vol. 1, Meet the Beatles!\16 Beatles, The -
                        It Won't Be Long (Mono).flac
                        Track 17: AccurateRip Verified Confidence 9, Pressing Offset +0 [ARv2 CRC 899EEBD1] Z:\Beatles, The\The Capitol Albums, Vol. 1, Meet the Beatles!\17 Beatles, The -
                        All I've Got To Do (Mono).flac
                        Track 18: AccurateRip Verified Confidence 10, Pressing Offset +0 [ARv2 CRC 30E4901B] Z:\Beatles, The\The Capitol Albums, Vol. 1, Meet the Beatles!\18 Beatles, The -
                        All My Loving (Mono).flac
                        Track 19: AccurateRip Verified Confidence 10, Pressing Offset +0 [ARv2 CRC 0EBDC266] Z:\Beatles, The\The Capitol Albums, Vol. 1, Meet the Beatles!\19 Beatles, The -
                        Don't Bother Me (Mono).flac
                        Track 20: AccurateRip Verified Confidence 10, Pressing Offset +0 [ARv2 CRC AD6FD63E] Z:\Beatles, The\The Capitol Albums, Vol. 1, Meet the Beatles!\20 Beatles, The -
                        Little Child (Mono).flac
                        Track 21: AccurateRip Verified Confidence 9, Pressing Offset +0 [ARv2 CRC 10F68421] Z:\Beatles, The\The Capitol Albums, Vol. 1, Meet the Beatles!\21 Beatles, The -
                        Till There Was You (Mono).flac
                        Track 22: AccurateRip Verified Confidence 9, Pressing Offset +0 [ARv2 CRC 374E91AE] Z:\Beatles, The\The Capitol Albums, Vol. 1, Meet the Beatles!\22 Beatles, The -
                        Hold Me Tight (Mono).flac
                        Track 23: AccurateRip Verified Confidence 9, Pressing Offset +0 [ARv2 CRC 860FD464] Z:\Beatles, The\The Capitol Albums, Vol. 1, Meet the Beatles!\23 Beatles, The -
                        I Wanna Be Your Man (Mono).flac
                        Track 24: AccurateRip Verified Confidence 10, Pressing Offset +0 [ARv2 CRC 8B478924] Z:\Beatles, The\The Capitol Albums, Vol. 1, Meet the Beatles!\24 Beatles, The -
                        Not A Second Time (Mono).flac
                        Beatles, The - The Capitol Albums, Vol. 2, Disc 1
                        Track 1: AccurateRip Verified Confidence 11, Pressing Offset +0 [ARv2 CRC 5AA86115] Z:\Beatles, The\The Capitol Albums, Vol. 2, Disc 1\01 Beatles, The - Love Me
                        Do.flac
                        Track 2: AccurateRip Verified Confidence 12, Pressing Offset +0 [ARv2 CRC 62F89F9A] Z:\Beatles, The\The Capitol Albums, Vol. 2, Disc 1\02 Beatles, The - Twist and
                        Shout.flac
                        Track 3: AccurateRip Verified Confidence 12, Pressing Offset +0 [ARv2 CRC F671E01D] Z:\Beatles, The\The Capitol Albums, Vol. 2, Disc 1\03 Beatles, The - Anna (Go to
                        Him).flac
                        Track 4: AccurateRip Verified Confidence 12, Pressing Offset +0 [ARv2 CRC FB36F553] Z:\Beatles, The\The Capitol Albums, Vol. 2, Disc 1\04 Beatles, The - Chains.flac
                        Track 5: AccurateRip Verified Confidence 11, Pressing Offset +0 [ARv2 CRC 374057DF] Z:\Beatles, The\The Capitol Albums, Vol. 2, Disc 1\05 Beatles, The - Boys.flac
                        Track 6: AccurateRip Verified Confidence 10, Pressing Offset +0 [ARv2 CRC EA2C747B] Z:\Beatles, The\The Capitol Albums, Vol. 2, Disc 1\06 Beatles, The - Ask Me
                        Why.flac
                        Track 7: AccurateRip Verified Confidence 11, Pressing Offset +0 [ARv2 CRC 7986B140] Z:\Beatles, The\The Capitol Albums, Vol. 2, Disc 1\07 Beatles, The - Please
                        Please Me.flac
                        Track 8: AccurateRip Verified Confidence 12, Pressing Offset +0 [ARv2 CRC 07D3F317] Z:\Beatles, The\The Capitol Albums, Vol. 2, Disc 1\08 Beatles, The - P.S. I Love
                        You.flac
                        Track 9: AccurateRip Verified Confidence 12, Pressing Offset +0 [ARv2 CRC 1CF7AAFD] Z:\Beatles, The\The Capitol Albums, Vol. 2, Disc 1\09 Beatles, The - Baby It's
                        You.flac
                        Track 10: AccurateRip Verified Confidence 12, Pressing Offset +0 [ARv2 CRC 8365D8C9] Z:\Beatles, The\The Capitol Albums, Vol. 2, Disc 1\10 Beatles, The - A Taste of
                        Honey.flac
                        Track 11: AccurateRip Verified Confidence 12, Pressing Offset +0 [ARv2 CRC E5DEED0C] Z:\Beatles, The\The Capitol Albums, Vol. 2, Disc 1\11 Beatles, The - Do You
                        Want to Know a Secret.flac
                        Track 12: AccurateRip Verified Confidence 12, Pressing Offset +0 [ARv2 CRC 4B34C541] Z:\Beatles, The\The Capitol Albums, Vol. 2, Disc 1\12 Beatles, The - Love Me Do
                        (Mono).flac
                        Track 13: AccurateRip Verified Confidence 11, Pressing Offset +0 [ARv2 CRC 97668648] Z:\Beatles, The\The Capitol Albums, Vol. 2, Disc 1\13 Beatles, The - Twist and
                        Shout (Mono).flac
                        Track 14: AccurateRip Verified Confidence 11, Pressing Offset +0 [ARv2 CRC E9842890] Z:\Beatles, The\The Capitol Albums, Vol. 2, Disc 1\14 Beatles, The - Anna (Go
                        to Him).flac
                        Track 15: AccurateRip Verified Confidence 11, Pressing Offset +0 [ARv2 CRC 5722F7CA] Z:\Beatles, The\The Capitol Albums, Vol. 2, Disc 1\15 Beatles, The - Chains
                        (Mono).flac
                        Track 16: AccurateRip Verified Confidence 11, Pressing Offset +0 [ARv2 CRC CC0D72FD] Z:\Beatles, The\The Capitol Albums, Vol. 2, Disc 1\16 Beatles, The - Boys
                        (Mono).flac
                        Track 17: AccurateRip Verified Confidence 11, Pressing Offset +0 [ARv2 CRC E9B98C97] Z:\Beatles, The\The Capitol Albums, Vol. 2, Disc 1\17 Beatles, The - Ask Me Why
                        (Mono).flac
                        Track 18: AccurateRip Verified Confidence 12, Pressing Offset +0 [ARv2 CRC 79B2C377] Z:\Beatles, The\The Capitol Albums, Vol. 2, Disc 1\18 Beatles, The - Please
                        Please Me (Mono).flac
                        Track 19: AccurateRip Verified Confidence 10, Pressing Offset +0 [ARv2 CRC 6DD4FA88] Z:\Beatles, The\The Capitol Albums, Vol. 2, Disc 1\19 Beatles, The - P.S. I
                        Love You.flac
                        Track 20: AccurateRip Verified Confidence 12, Pressing Offset +0 [ARv2 CRC 77C0B7C1] Z:\Beatles, The\The Capitol Albums, Vol. 2, Disc 1\20 Beatles, The - Baby It's
                        You (Mono).flac
                        Track 21: AccurateRip Verified Confidence 10, Pressing Offset +0 [ARv2 CRC 3BF8ED5B] Z:\Beatles, The\The Capitol Albums, Vol. 2, Disc 1\21 Beatles, The - A Taste of
                        Honey (Mono).flac
                        Track 22: AccurateRip Verified Confidence 10, Pressing Offset +0 [ARv2 CRC AF70FB70] Z:\Beatles, The\The Capitol Albums, Vol. 2, Disc 1\22 Beatles, The - Do You
                        Want to Know a Secret (Mono).flac
                        Beatles, The - The Capitol Albums, Vol. 2, Disc 2
                        Track 1: AccurateRip Verified Confidence 6, Pressing Offset +0 [ARv2 CRC 91CEAE38] Z:\Beatles, The\The Capitol Albums, Vol. 2, Disc 2\01 Beatles, The - Kansas
                        City.flac
                        Track 2: AccurateRip Verified Confidence 6, Pressing Offset +0 [ARv2 CRC 62588911] Z:\Beatles, The\The Capitol Albums, Vol. 2, Disc 2\02 Beatles, The - Eight Days a
                        Week.flac
                        Track 3: AccurateRip Verified Confidence 6, Pressing Offset +0 [ARv2 CRC 0D91B8E4] Z:\Beatles, The\The Capitol Albums, Vol. 2, Disc 2\03 Beatles, The - You Like Me
                        Too Much.flac
                        Track 4: AccurateRip Verified Confidence 6, Pressing Offset +0 [ARv2 CRC 840B04F6] Z:\Beatles, The\The Capitol Albums, Vol. 2, Disc 2\04 Beatles, The - Bad Boy.flac
                        Track 5: AccurateRip Verified Confidence 6, Pressing Offset +0 [ARv2 CRC ADF67BC9] Z:\Beatles, The\The Capitol Albums, Vol. 2, Disc 2\05 Beatles, The - I Don't Want
                        to Spoil the Party.flac
                        Track 6: AccurateRip Verified Confidence 5, Pressing Offset +0 [ARv2 CRC B8CF4681] Z:\Beatles, The\The Capitol Albums, Vol. 2, Disc 2\06 Beatles, The - Words of
                        Love.flac
                        Track 7: AccurateRip Verified Confidence 6, Pressing Offset +0 [ARv2 CRC C4CBB0D5] Z:\Beatles, The\The Capitol Albums, Vol. 2, Disc 2\07 Beatles, The - What You're
                        Doing.flac
                        Track 8: AccurateRip Verified Confidence 6, Pressing Offset +0 [ARv2 CRC 8B4470C4] Z:\Beatles, The\The Capitol Albums, Vol. 2, Disc 2\08 Beatles, The - Yes It
                        Is.flac
                        Track 9: AccurateRip Verified Confidence 6, Pressing Offset +0 [ARv2 CRC 4E4A4BC9] Z:\Beatles, The\The Capitol Albums, Vol. 2, Disc 2\09 Beatles, The - Dizzy Miss
                        Lizzie.flac
                        Track 10: AccurateRip Verified Confidence 5, Pressing Offset +0 [ARv2 CRC 724E0DAC] Z:\Beatles, The\The Capitol Albums, Vol. 2, Disc 2\10 Beatles, The - Tell Me
                        What You See.flac
                        Track 11: AccurateRip Verified Confidence 6, Pressing Offset +0 [ARv2 CRC 5E1895FC] Z:\Beatles, The\The Capitol Albums, Vol. 2, Disc 2\11 Beatles, The - Every
                        Little Thing.flac
                        Track 12: AccurateRip Verified Confidence 5, Pressing Offset +0 [ARv2 CRC 6F2582F5] Z:\Beatles, The\The Capitol Albums, Vol. 2, Disc 2\12 Beatles, The - Kansas
                        City.flac
                        Track 13: AccurateRip Verified Confidence 5, Pressing Offset +0 [ARv2 CRC E658818A] Z:\Beatles, The\The Capitol Albums, Vol. 2, Disc 2\13 Beatles, The - Eight Days
                        a Week.flac
                        Track 14: AccurateRip Verified Confidence 5, Pressing Offset +0 [ARv2 CRC 59A896CC] Z:\Beatles, The\The Capitol Albums, Vol. 2, Disc 2\14 Beatles, The - You Like Me
                        Too Much.flac
                        Track 15: AccurateRip Verified Confidence 5, Pressing Offset +0 [ARv2 CRC E672F9DD] Z:\Beatles, The\The Capitol Albums, Vol. 2, Disc 2\15 Beatles, The - Bad
                        Boy.flac
                        Track 16: AccurateRip Verified Confidence 6, Pressing Offset +0 [ARv2 CRC 86ADAD64] Z:\Beatles, The\The Capitol Albums, Vol. 2, Disc 2\16 Beatles, The - I Don't
                        Want to Spoil the Party.flac
                        Track 17: AccurateRip Verified Confidence 6, Pressing Offset +0 [ARv2 CRC E3E360DC] Z:\Beatles, The\The Capitol Albums, Vol. 2, Disc 2\17 Beatles, The - Words of
                        Love.flac
                        Track 18: AccurateRip Verified Confidence 6, Pressing Offset +0 [ARv2 CRC 1E062564] Z:\Beatles, The\The Capitol Albums, Vol. 2, Disc 2\18 Beatles, The - What You're
                        Doing.flac
                        Track 19: AccurateRip Verified Confidence 6, Pressing Offset +0 [ARv2 CRC DA050BAC] Z:\Beatles, The\The Capitol Albums, Vol. 2, Disc 2\19 Beatles, The - Yes It
                        Is.flac
                        Track 20: AccurateRip Verified Confidence 6, Pressing Offset +0 [ARv2 CRC 750A9704] Z:\Beatles, The\The Capitol Albums, Vol. 2, Disc 2\20 Beatles, The - Dizzy Miss
                        Lizzie.flac
                        Track 21: AccurateRip Verified Confidence 5, Pressing Offset +0 [ARv2 CRC D9F391EA] Z:\Beatles, The\The Capitol Albums, Vol. 2, Disc 2\21 Beatles, The - Tell Me
                        What You See.flac
                        Track 22: AccurateRip Verified Confidence 5, Pressing Offset +0 [ARv2 CRC 6208F240] Z:\Beatles, The\The Capitol Albums, Vol. 2, Disc 2\22 Beatles, The - Every
                        Little Thing.flac
                        • Gbeer7
                          • Mar 2011
                          • 165
                          #27
                          and finally....
                          Beatles, The - The Capitol Albums, Vol. 2, Disc 3
                          Track 1: AccurateRip Verified Confidence 10, Pressing Offset +0 [ARv2 CRC 3F35AC9B] Z:\Beatles, The\The Capitol Albums, Vol. 2, Disc 3\01 Beatles, The - Help!.flac
                          Track 2: AccurateRip Verified Confidence 11, Pressing Offset +0 [ARv2 CRC E4A17507] Z:\Beatles, The\The Capitol Albums, Vol. 2, Disc 3\02 Beatles, The - The Night
                          Before.flac
                          Track 3: AccurateRip Verified Confidence 11, Pressing Offset +0 [ARv2 CRC EC832911] Z:\Beatles, The\The Capitol Albums, Vol. 2, Disc 3\03 Beatles, The - From Me to
                          You Fantasy (instrumental).flac
                          Track 4: AccurateRip Verified Confidence 11, Pressing Offset +0 [ARv2 CRC 7E81DC27] Z:\Beatles, The\The Capitol Albums, Vol. 2, Disc 3\04 Beatles, The - You've Got
                          to Hide Your Love Away.flac
                          Track 5: AccurateRip Verified Confidence 11, Pressing Offset +0 [ARv2 CRC E6FAD73D] Z:\Beatles, The\The Capitol Albums, Vol. 2, Disc 3\05 Beatles, The - I Need
                          You.flac
                          Track 6: AccurateRip Verified Confidence 11, Pressing Offset +0 [ARv2 CRC 3A4C1B50] Z:\Beatles, The\The Capitol Albums, Vol. 2, Disc 3\06 Beatles, The - In the
                          Tyrol (instrumental).flac
                          Track 7: AccurateRip Verified Confidence 10, Pressing Offset +0 [ARv2 CRC 17D37DFD] Z:\Beatles, The\The Capitol Albums, Vol. 2, Disc 3\07 Beatles, The - Another
                          Girl.flac
                          Track 8: AccurateRip Verified Confidence 11, Pressing Offset +0 [ARv2 CRC 64C1024D] Z:\Beatles, The\The Capitol Albums, Vol. 2, Disc 3\08 Beatles, The - Another
                          Hard Day's Night (instrumental).flac
                          Track 9: AccurateRip Verified Confidence 11, Pressing Offset +0 [ARv2 CRC 3F85B0E3] Z:\Beatles, The\The Capitol Albums, Vol. 2, Disc 3\09 Beatles, The - Ticket to
                          Ride.flac
                          Track 10: AccurateRip Verified Confidence 11, Pressing Offset +0 [ARv2 CRC F2BEFAF7] Z:\Beatles, The\The Capitol Albums, Vol. 2, Disc 3\10 Beatles, The - The Bitter
                          End-You Can't Do That.flac
                          Track 11: AccurateRip Verified Confidence 11, Pressing Offset +0 [ARv2 CRC FA1837BF] Z:\Beatles, The\The Capitol Albums, Vol. 2, Disc 3\11 Beatles, The - You're
                          Gonna Lose That Girl.flac
                          Track 12: AccurateRip Verified Confidence 10, Pressing Offset +0 [ARv2 CRC 3159EA11] Z:\Beatles, The\The Capitol Albums, Vol. 2, Disc 3\12 Beatles, The - The Chase
                          (instrumental).flac
                          Track 13: AccurateRip Verified Confidence 10, Pressing Offset +0 [ARv2 CRC D03ECB5D] Z:\Beatles, The\The Capitol Albums, Vol. 2, Disc 3\13 Beatles, The - Help!
                          (Mono).flac
                          Track 14: AccurateRip Verified Confidence 10, Pressing Offset +0 [ARv2 CRC 08F0449E] Z:\Beatles, The\The Capitol Albums, Vol. 2, Disc 3\14 Beatles, The - The Night
                          Before (Mono).flac
                          Track 15: AccurateRip Verified Confidence 10, Pressing Offset +0 [ARv2 CRC 66241EED] Z:\Beatles, The\The Capitol Albums, Vol. 2, Disc 3\15 Beatles, The - From Me to
                          You Fantasy (instrumental) (mono).flac
                          Track 16: AccurateRip Verified Confidence 11, Pressing Offset +0 [ARv2 CRC 5A6A0B94] Z:\Beatles, The\The Capitol Albums, Vol. 2, Disc 3\16 Beatles, The - You've Got
                          to Hide Your Love Away (Mono).flac
                          Track 17: AccurateRip Verified Confidence 10, Pressing Offset +0 [ARv2 CRC BA8C0CAE] Z:\Beatles, The\The Capitol Albums, Vol. 2, Disc 3\17 Beatles, The - I Need You
                          (Mono).flac
                          Track 18: AccurateRip Verified Confidence 11, Pressing Offset +0 [ARv2 CRC 0F246FC5] Z:\Beatles, The\The Capitol Albums, Vol. 2, Disc 3\18 Beatles, The - In the
                          Tyrol (instrumental) (mono).flac
                          Track 19: AccurateRip Verified Confidence 11, Pressing Offset +0 [ARv2 CRC 6CA922C6] Z:\Beatles, The\The Capitol Albums, Vol. 2, Disc 3\19 Beatles, The - Another
                          Girl (Mono).flac
                          Track 20: AccurateRip Verified Confidence 11, Pressing Offset +0 [ARv2 CRC EFAFE4A9] Z:\Beatles, The\The Capitol Albums, Vol. 2, Disc 3\20 Beatles, The - Another
                          Hard Day's Night (instrumental) (mono).flac
                          Track 21: AccurateRip Verified Confidence 8, Pressing Offset +0 [ARv2 CRC 15E2C5DD] Z:\Beatles, The\The Capitol Albums, Vol. 2, Disc 3\21 Beatles, The - Ticket to
                          Ride (Mono).flac
                          Track 22: AccurateRip Verified Confidence 9, Pressing Offset +0 [ARv2 CRC 292F3063] Z:\Beatles, The\The Capitol Albums, Vol. 2, Disc 3\22 Beatles, The - The Bitter
                          Track 23: AccurateRip Verified Confidence 9, Pressing Offset +0 [ARv2 CRC 7C21E134] Z:\Beatles, The\The Capitol Albums, Vol. 2, Disc 3\23 Beatles, The - You're
                          Gonna Lose That Girl (Mono).flac
                          Track 24: AccurateRip Verified Confidence 7, Pressing Offset +0 [ARv2 CRC 3A6F756B] Z:\Beatles, The\The Capitol Albums, Vol. 2, Disc 3\24 Beatles, The - The Chase
                          (Instrumental) (Mono).flac
                          Beatles, The - The Capitol Albums, Vol. 2, Disc 4
                          Track 1: AccurateRip Verified Confidence 6, Pressing Offset +0 [ARv2 CRC 621A00C3] Z:\Beatles, The\The Capitol Albums, Vol. 2, Disc 4\01 Beatles, The - I've Just
                          Seen a Face.flac
                          Track 2: AccurateRip Verified Confidence 6, Pressing Offset +0 [ARv2 CRC 3ECE82A4] Z:\Beatles, The\The Capitol Albums, Vol. 2, Disc 4\02 Beatles, The - Norwegian
                          Wood (This Bird Has Flown).flac
                          Track 3: AccurateRip Verified Confidence 6, Pressing Offset +0 [ARv2 CRC 77F4C52B] Z:\Beatles, The\The Capitol Albums, Vol. 2, Disc 4\03 Beatles, The - You Won't
                          See Me.flac
                          Track 4: AccurateRip Verified Confidence 6, Pressing Offset +0 [ARv2 CRC 1E01694E] Z:\Beatles, The\The Capitol Albums, Vol. 2, Disc 4\04 Beatles, The - Think for
                          Yourself.flac
                          Track 5: AccurateRip Verified Confidence 5, Pressing Offset +0 [ARv2 CRC 56CF27DC] Z:\Beatles, The\The Capitol Albums, Vol. 2, Disc 4\05 Beatles, The - The
                          Word.flac
                          Track 6: AccurateRip Verified Confidence 5, Pressing Offset +0 [ARv2 CRC D6E5400E] Z:\Beatles, The\The Capitol Albums, Vol. 2, Disc 4\06 Beatles, The -
                          Michelle.flac
                          Track 7: AccurateRip Verified Confidence 6, Pressing Offset +0 [ARv2 CRC 383463A7] Z:\Beatles, The\The Capitol Albums, Vol. 2, Disc 4\07 Beatles, The - It's Only
                          Love.flac
                          Track 8: AccurateRip Verified Confidence 6, Pressing Offset +0 [ARv2 CRC CE3F91B0] Z:\Beatles, The\The Capitol Albums, Vol. 2, Disc 4\08 Beatles, The - Girl.flac
                          Track 9: AccurateRip Verified Confidence 6, Pressing Offset +0 [ARv2 CRC C9A8CC5E] Z:\Beatles, The\The Capitol Albums, Vol. 2, Disc 4\09 Beatles, The - I'm Looking
                          Through You.flac
                          Track 10: AccurateRip Verified Confidence 6, Pressing Offset +0 [ARv2 CRC 71B7BA95] Z:\Beatles, The\The Capitol Albums, Vol. 2, Disc 4\10 Beatles, The - In My
                          Life.flac
                          Track 11: AccurateRip Verified Confidence 5, Pressing Offset +0 [ARv2 CRC E065843B] Z:\Beatles, The\The Capitol Albums, Vol. 2, Disc 4\11 Beatles, The - Wait.flac
                          Track 12: AccurateRip Verified Confidence 6, Pressing Offset +0 [ARv2 CRC B97AEA9A] Z:\Beatles, The\The Capitol Albums, Vol. 2, Disc 4\12 Beatles, The - Run for
                          Your Life.flac
                          Track 13: AccurateRip Verified Confidence 5, Pressing Offset +0 [ARv2 CRC 2E2694AC] Z:\Beatles, The\The Capitol Albums, Vol. 2, Disc 4\13 Beatles, The - I've Just
                          Seen a Face.flac
                          Track 14: AccurateRip Verified Confidence 4, Pressing Offset +0 [ARv2 CRC C56C0CC9] Z:\Beatles, The\The Capitol Albums, Vol. 2, Disc 4\14 Beatles, The - Norwegian
                          Track 15: AccurateRip Verified Confidence 5, Pressing Offset +0 [ARv2 CRC 3A0283E6] Z:\Beatles, The\The Capitol Albums, Vol. 2, Disc 4\15 Beatles, The - You Won't
                          See Me.flac
                          Track 16: AccurateRip Verified Confidence 6, Pressing Offset +0 [ARv2 CRC 5A0ADE3F] Z:\Beatles, The\The Capitol Albums, Vol. 2, Disc 4\16 Beatles, The - Think for
                          Yourself.flac
                          Track 17: AccurateRip Verified Confidence 5, Pressing Offset +0 [ARv2 CRC 16FAB8F4] Z:\Beatles, The\The Capitol Albums, Vol. 2, Disc 4\17 Beatles, The - The
                          Word.flac
                          Track 18: AccurateRip Verified Confidence 6, Pressing Offset +0 [ARv2 CRC 7E33A2DD] Z:\Beatles, The\The Capitol Albums, Vol. 2, Disc 4\18 Beatles, The -
                          Michelle.flac
                          Track 19: AccurateRip Verified Confidence 6, Pressing Offset +0 [ARv2 CRC ACA2C563] Z:\Beatles, The\The Capitol Albums, Vol. 2, Disc 4\19 Beatles, The - It's Only
                          Love.flac
                          Track 20: AccurateRip Verified Confidence 6, Pressing Offset +0 [ARv2 CRC 050489F3] Z:\Beatles, The\The Capitol Albums, Vol. 2, Disc 4\20 Beatles, The - Girl.flac
                          Track 21: AccurateRip Verified Confidence 6, Pressing Offset +0 [ARv2 CRC C7A8051E] Z:\Beatles, The\The Capitol Albums, Vol. 2, Disc 4\21 Beatles, The - I'm Looking
                          Through You.flac
                          Track 22: AccurateRip Verified Confidence 6, Pressing Offset +0 [ARv2 CRC 9689369E] Z:\Beatles, The\The Capitol Albums, Vol. 2, Disc 4\22 Beatles, The - In My
                          Life.flac
                          Track 23: AccurateRip Verified Confidence 5, Pressing Offset +0 [ARv2 CRC 4FCC1970] Z:\Beatles, The\The Capitol Albums, Vol. 2, Disc 4\23 Beatles, The - Wait.flac
                          Track 24: AccurateRip Verified Confidence 4, Pressing Offset +0 [ARv2 CRC F42E181E] Z:\Beatles, The\The Capitol Albums, Vol. 2, Disc 4\24 Beatles, The - Run for
                          Your Life.flac
                            • 5744
                            #28
                            yes, these rips are all accurraterip verified. They all look good. You really must learn and understand how accurraterip works. Then you would understand for yourself that all these rips are good and verified simply from looking at the log. You're done with these rips! keep a backup and listen and enjoy the music.
                            • Porcus
                              • Feb 2007
                              • 792
                              #29
                              garym is right. The only thing you cannot trust about PerfectTUNES (that is, until Spoon implements a workaround -- remember the software is in beta stage, don't expect it to work as a final product!), is a confidence of 1, if you have already submitted one yourself. (For then you are comparing to your own rip, which of course always matches.)
                              • Gilbey
                                • Jul 2012
                                I apologize for jumping in on this thread, but where on the website do I start a new thread with a new question? I have just registered. Thanks.
