major problem
  • simon_killie1
    • Jul 2003
    major problem
    when tryin to convert an .mpga file to an .mp3, i recieve the same error every time:
    ie. "The CODEC required to decompress 'C:\My Documents\My Music\Single tunez\BCDProject-TuttiFrutti(BCDProjectRmx).mpga' could not be opened."
    wot?!?!
    previous to receiving these errors i had been able to convert 10 mpga files to mp3, why has this changed????
  • mooq!
    • Jul 2003
    try reinstalling the codec. (codec central)
    • simon_killie1
      • Jul 2003
      how?
      beside the mpga codec file that i require, it does not have the option to download??
        • 43930
        It is possible it is a 'bad' file, have you tried to play it in another player?
          help
          there 65 files that i get the error with, and they all play fine in a player, its just that id rather they were in mp3 format
            cant convert to wav either
            i cant convert these files to wav format either now
              • 43930
              It is the reading part that cannot read it, so you will not be able to convert to anything.
