Ok to convert FLAC (Lossless Level 0) to FLAC (Lossless Level 8) ?
  • engjoo
    • Feb 2012
    I know it can be done but will I suffer any loss in quality ? I know it may sound like a stupid question but I wanted some assurances before I start doing it on my entire collection.
    Running low in storage space and needed to free up some capacity.
  • Jeff Flowerday
    • Mar 2008
    • 105
    Re: Ok to convert FLAC (Lossless Level 0) to FLAC (Lossless Level 8) ?
    No loss in quality. Lossless is lossless. The higher compression level will just require more CPU to decode and encode as well.
    • Porcus
      • Feb 2007
      • 792
      Only the encoding effort -- FLAC is a codec which isn't slower at higher compression levels. The decoding times at http://flac.sourceforge.net/comparis...ocdectime.html are not even monotone wrt. compression levels, and the differences are probably just by coincidence.
      Apart from that, yes, lossless is lossless (as long as the target format actually supports the source format).
