Missing metadata form Flac to AIFF conversion
  • jfpierce
    • Jan 2012
    • 12
    Re: Missing metadata form Flac to AIFF conversion
    Here it is.
    Splitting Command Line:Done
    ->-> [dBCoreConverter::ReaddBCommandFile]
    <-<- [dBCoreConverter::ReaddBCommandFile]
    ->-> [cldBCodecHandler::FindDecoder]
    Checking Decoder 'C:\Program Files\Illustrate\dBpoweramp\decoder\mp3.dll' for extension '.mp3'
    Decodes [clDecoder::Get]
    <<< Match, using decoder
    Using Registry Cached Decoder: C:\Program Files\Illustrate\dBpoweramp\decoder\mp3.dll
    <-<- [cldBCodecHandler::FindDecoder]
    BatchID [clDecoder::Set]
    ->-> [cldBCodecHandler::LoadEncoder]
    Loading Encoder 'C:\Program Files\Illustrate\dBpoweramp\encoder\Aiff.DLL'
    <-<- [cldBCodecHandler::LoadEncoder]
    BatchID [clEncoder::Set]
    ->-> [dBCoreConverter::StripCoreConverterCmds]
    <-<- [dBCoreConverter::StripCoreConverterCmds]
    SendRawUnCompressed [clEncoder::Get]
    Communicate [clDecoder::Get]
    Communicate [clEncoder::Get]
    NeedHQAudio [clEncoder::Get]
    ->-> [clDecoder::Open]
    Opening file '\\N12000\iTunes_music\01 Man In Motion.mp3' for read access: Opened
    ->-> [clDecoder::ReadIDTags]
    Reading Tag: APE contained 0 tags:
    Reading Tag: ID3v2 contained 14 tags:
    Title: Man In Motion
    Artist: Warren Haynes
    Composer: Warren Haynes
    Album: Man in Motion
    Track: 1/10
    Disc: 1/1
    Year: 2011
    Genre: Rock
    Comment iTunPGAP: 0
    Encoded by: iTunes 10.5.2
    Comment iTunNORM: 00001BE0 000016F1 000152BE 00018092 00028582 00028582 00008BB5 00008AA9 00032258 000313C1
    Comment iTunSMPB: 00000000 00000210 00000B28 00000000013DE248 00000000 00734CBD 00000000 00000000 00000000 00000000 00000000 00000000
    Comment iTunes_CDDB_1: 890F7C0A+297473+10+150+35580+66412+91096+122362+15 5239+189590+219086+244894+269261
    Comment iTunes_CDDB_TrackNumber: 1
    Reading Tag: ID3v1 contained 0 tags:
    <-<- [clDecoder::ReadIDTags]
    ->-> [clsmpeg123::Init]
    mpeg data stream begins at byte position: 2232
    <-<- [clsmpeg123::Init]
    ->-> [clDecoder::FillAudioProps]
    Audio Quality: Low (Lossy)
    Encoder: FHG (Guess)
    Encoder Settings: Constant Bit Rate 128 kbps
    Channel Mapping: Left, Right
    Channel Coupling: Joint-Stereo
    Sample Count: 20,836,191
    MPEG Version: MPEG 1 Layer III
    MPEG Technical: Header: (none) Bits: (none)
    ID Tag: ID3v2.2 (ANSI)
    Contains: ID Tag [ID3v2.2 (ANSI)]
    Gapless: No
    <-<- [clDecoder::FillAudioProps]
    ->-> [clDecoder::FillAudioInfo]
    Uncompressed WFX (sent to db): Format Tag: 1 Channels: 2 Bits per Sample: 16 Samples Per Second: 44100 Bytes Per Second: 176400 Block Align: 4 CB Size: 0
    Audio Length: 472475 mili-seconds 7559628 bytes 128 kbps
    <-<- [clDecoder::FillAudioInfo]
    Creating Decode Buffer: Created
    <-<- [clDecoder::Open]
    SendOverReplayGainTags [clEncoder::Get]
    ->-> [clEncoder::BeginConversion]
    Professional sample rate conversion.
    Converting to '\\N12000\iTunes_music\01 Man In Motion.aif' encoder settings ''
    ->-> [clAIFFHandler::InitializeNewAIFF]
    clAIFFHandler::CalcAllChunks: Ok
    ->-> [clAIFFHandler::AddChunk]
    ->-> Adding Chunk 'COMM' Length: 18 [clAIFFHandler::AddChunk]
    <-<- [clAIFFHandler::AddChunk]
    ->-> Adding Chunk 'SSND' Length: 0 [clAIFFHandler::AddChunk]
    ->-> [clAIFFHandler::WriteChunkHeaders]
    Writing Chunk Header 'COMM' Length: 18 ChunkPosition: 12 ChunkDataPos: 20
    Writing Chunk Header 'SSND' Length: 0 ChunkPosition: 38 ChunkDataPos: 46
    <-<- Exit as only write to SSND chunk [clAIFFHandler::WriteChunkHeaders]
    Writing Chunk Data 'COMM' Length: 18 ChunkPosition: 12 ChunkDataPos: 20
    <-<- [clAIFFHandler::InitializeNewAIFF]
    Writing STSoundData
    <-<- [clEncoder::BeginConversion]
    Encoding To: Aiff
    Encoder Cmd Line:
    ->-> [dBCoreConverter::CloseDecoder]
    ->-> [clDecoder::Close]
    <-<- [clDecoder::Close]
    ->-> [clEncoder::EndConversion]
    Writing Chunk Header 'SSND' Length: 83342788 ChunkPosition: 38 ChunkDataPos: 46
    <-<- [clAIFFHandler::WriteChunkHeaders]
    <-<- [clEncoder::EndConversion]
    File Size Check : 83342834 bytes Filename: \\N12000\iTunes_music\01 Man In Motion.aif
    File Size Check (before ID Tags Written): 83342834 bytes Filename: \\N12000\iTunes_music\01 Man In Motion.aif
    ->-> [dBCoreConverter::IDTagWriter]
    Checking Decoder 'C:\Program Files\Illustrate\dBpoweramp\decoder\Aiff.dll' for extension '.aif'
    Using Registry Cached Decoder: C:\Program Files\Illustrate\dBpoweramp\decoder\Aiff.dll
    IDTags [clDecoder::Set]
    ->-> [clWaveDecoder::WriteIDTags]
    ->-> [clWaveDecoder::IDTagWriter]
    Opening file '\\N12000\iTunes_music\01 Man In Motion.aif' for write access: Opened
    ->-> [clAIFFHandler::Initialize]
    <-<- [clAIFFHandler::Initialize]
    ->-> [clAIFFHandler::ScanFile]
    AIFF Header 'FORM' Length: 83342826 FormType 'AIFF' [clAIFFHandler::ScanFile]
    Got Chunk 'COMM' Length: 18 RiffSizeLeft: 83342814 ChunkPosition: 12
    Got Chunk 'SSND' Length: 83342788 RiffSizeLeft: 83342788 ChunkPosition: 38
    <-<- [clAIFFHandler::ScanFile]
    ->-> [clWaveDecoder::InternalReadTags]
    <-<- [clWaveDecoder::InternalReadTags]
    ->-> [clAIFFHandler::AddNewChunkToFile]
    ->-> Adding Chunk 'ID3 ' Length: 10 [clAIFFHandler::AddChunk]
    Writing Chunk Data 'ID3 ' Length: 10 ChunkPosition: 83342834 ChunkDataPos: 83342842
    <-<- [clAIFFHandler::AddNewChunkToFile]
    chunk index: 2->-> [clAIFFHandler::ResizeExistingChunkOnFile]
    Writing Chunk Header 'ID3 ' Length: 2048 ChunkPosition: 83342834 ChunkDataPos: 83342842
    <-<- [clAIFFHandler::ResizeExistingChunkOnFile]
    <-<- [clWaveDecoder::IDTagWriter]
    <-<- [clWaveDecoder::WriteIDTags]
    <-<- [dBCoreConverter::IDTagWriter]
    Conversion completed in 5.1 seconds x92 realtime encoding
    File Size Check (core converter exit): 83344890 bytes Filename: \\N12000\iTunes_music\01 Man In Motion.aif
    • jfpierce
      • Jan 2012
      • 12
      Not sure if you saw the debugging log that I posted. I would like solve this issue. FYI, JRiver can read the metadata in the AIFF files.
      • bjast
        • Mar 2011
        • 72
        I'm having a similar situation, and was wondering it you received a solution?
        • jfpierce
          • Jan 2012
          • 12
          I haven't received a response to the debug log that I posted. Perhaps you could start a new thread. Thanks
            • 43928
            Please drop an email:
            we need to add extra logging information, as the above log shows that the tags disappear somewhere between reading >> writing, but not where.
