Commandline error when using LAME with CLI Encoder
  • zipzip
    • May 2010
    • 14
    I've been using the following commandline in the CLI encoder with the new LAME 3.99.2:
    --noreplaygain -b 256 -q 7 [IFCOMP]--compilation[] - "[outfile_long]"
    Works great on single-artist albums, but for various artist compilations, it creates a corrupted file that's only about 2kb in size, and I get this error:
    Error converting to CLI Encoder, "[path]" Error writing audio data to StdIn Pipe [clEncoder::EncodeBlock]
    The whole [IFCOMP]--compilation[] - "[outfile_long]" thing works perfectly on various artists compilations using Quicktime AAC Encoder. I can't figure out why I get the error when I change encoders. It's just the [IFCOMP]--compilation[] part of the commandline that is not working with the LAME for some reason.
    Any ideas what I'm doing wrong? Why does this work with Quicktime AAC and not with LAME?
    • 43928
    Re: Commandline error when using LAME with CLI Encoder
    >--compilation
    Why do you need this? dBpoweramp writes the tags after converting.
    • zipzip
      • May 2010
      • 14
      >--compilation
      Maybe I don't. That's part of the command line another user gave me a couple of years ago, and I've always used it. To be honest, I've never even known exactly what "[IFCOMP]--compilation[]" does.
      • dbfan
        • Jan 2011
        • 937
        Remove it, not needed
