Making multiple versions with volume differentials
  • chrisjj
    • Nov 2008
    • 300
    What is the best way to convert from a single input file to multiple output files each having volume normalised to ReplayGain /plus/ adjusted by a different differential? E.g.
    out1 ReplayGain + 6dB
    out2 ReplayGain
    out3 ReplayGain - 6dB
    out4 ReplayGain - 12dB
    To minimise execution time and maximise output quality, I would like to avoid redundant ReplayGain calculation and transcoding.
    • 43982
    Re: Making multiple versions with volume differentials
    You would calculate RG and store in the ID Tags (utitlity codec [ReplayGain]).
    Then you would convert the file >> Multi Encoder and use ReplayGain (apply).
    • chrisjj
      • Nov 2008
      • 300
      Thanks. Where best to apply the differential?
        • 43982
        1st Pass (batch converter) calc replaygain,
        2nd Pass use Multi Encoder, and use the DSP effect volume normalize (use it twice, one with replaygain and one with the fixed amplification).
        • chrisjj
          • Nov 2008
          • 300
          Ah, neat. Thanks.
