Problem using CLI encoder + flac.exe
  • exec
    • Dec 2007
    • 53
    Hi!
    Trying to set up a command line using the CLI (latest version) encoder in combination of flac.exe (also latest version). It doesn't matter what I try, I always get the error "Error reading metadata" when the track was ripped and is up for encoding. Then the resulting flac file has 0 bytes.
    My command line looks like this:
    [infile] [outfile]
    I've already tried different combinations (e.g. with a leading space), (un) ticked the options of the CLI encoder, set the right extension (.flac) in the encoder.txt file, but nothing seems to work.
    Any suggestions?
    PS: And yes, I know that a flac decoder comes with dbpoweramp already. But I still want to use the CLI encoder.
    • 45180
    Re: Problem using CLI encoder + flac.exe
    Flac would need something other than [infile] [outfile]?
    perhaps try in quotes:
    "[infile]" "[outfile]"
    • exec
      • Dec 2007
      • 53
      As I said, I've tried everything, with quotes, without quotes, with different flac commandline options, etc. - nothing seems to work.
      Well, I think that the error message is a little strange. What metadata should be read?
        • 45180
        That is later on when the audio track should have been written, as flac.exe is not writing anything this is causing our tagging routine to fail.
        • exec
          • Dec 2007
          • 53
          OK, before spending much time figuring out how to get CLI + flac.exe to work, here's another question:
          What are the tagging abilities when using CLI + flac.exe when ticking the ID tag option of the CLI encoder? Would dbpoweramp recogize that flac files should be tagged and use vorbis tags rather then ID3 tags?
            • 45180
            dBpoweramp would tag the file always with Vorbis comments.
            • exec
              • Dec 2007
              • 53
              Now I've tried to get this working for a few days, without success...
              Well, I've switched the music converter in debug mode, and here is what I've got:
              Code:
              Splitting Command Line:Done
              ->->  [dBCoreConverter::ReaddBCommandFile]
              <-<-  [dBCoreConverter::ReaddBCommandFile]
              Allying to Processor 1
              ->->  [cldBCodecHandler::LoadEncoder]
                Loading Encoder 'C:\Program Files (x86)\Illustrate\dBpoweramp\encoder\CLI Encoder.DLL'
              <-<-  [cldBCodecHandler::LoadEncoder]
              BatchID  [clEncoder::Set]
              ->->  [dBCoreConverter::StripCoreConverterCmds]
              <-<-  [dBCoreConverter::StripCoreConverterCmds]
              SendRawUnCompressed  [clEncoder::Get]
              Communicate  [clEncoder::Get]
              ->->  [dBCoreConverter::OpenDecoder]
                Reading StdIn Tmp File IDTags: Read
                Using StdInput WFX:Format Tag: 1  Channels: 2  Bits per Sample: 16  Samples Per Second: 44100  Bytes Per Second: 176400  Block Align: 4  CB Size: 0
              <-<-  [dBCoreConverter::OpenDecoder]
              SendOverReplayGainTags  [clEncoder::Get]
              ->->  [clEncoder::BeginConversion]
                Converting to 'C:\Users\User\Music\Rotten Sound\Rotten Sound - Veenom.flac.tmp.flac' encoder settings ' -cli_encoder="C:\Program Files (x86)\Encoders\FLAC\bin\flac.exe" -cli_cmd=" -o [outfile] [infile]" -nodbtag'
                Using Encoder 'C:\Program Files (x86)\Encoders\FLAC\bin\flac.exe'
                Command Line ' -o C:\Users\User\Music\ROTTEN~1\ROTTEN~2.FLA C:\Users\User\Music\ROTTEN~1\ROTTEN~1.WAV'
                Input Wave Format:Format Tag: 1  Channels: 2  Bits per Sample: 16  Samples Per Second: 44100  Bytes Per Second: 176400  Block Align: 4  CB Size: 0
                Output Wave Format:Format Tag: 1  Channels: 2  Bits per Sample: 16  Samples Per Second: 44100  Bytes Per Second: 176400  Block Align: 4  CB Size: 0
                Passing Wave Header: Yes
                Using StdInput Pipe: No
                dBpoweramp Writing Tags: No
              <-<-  [clEncoder::BeginConversion]
              Encoding To: CLI Encoder
              Encoder Cmd Line:  -cli_encoder="C:\Program Files (x86)\Encoders\FLAC\bin\flac.exe" -cli_cmd=" -o [outfile] [infile]" -nodbtag
              ->->  [dBCoreConverter::CloseDecoder]
                <-<-  [dBCoreConverter::CloseDecoder]
              ->->  [clEncoder::EndConversion]
                Running program after conversion 'C:\Program Files (x86)\Illustrate\dBpoweramp\encoder\CLI Encoder\' Command Line:
                Program completed
              <-<-  [clEncoder::EndConversion]
                Conversion completed in 249 mili-seconds x22 realtime encoding
              And it looks like it is using a file extension of ".FLA" - where does this come from? In the encoder.txt, there's only given ".flac" as extension.
              I can't see the problem here, because flac.exe needs something like
              Code:
              flac -o myFileName.flac myFileName.wav
              What else can I try?
                • 45180
                You must have the option in Windows to disable the short pathnames, because to handle unicode the short pathname is generated from the long pathname. Ie:
                is passed when it really is:
                C:\Users\User\Music\ROTTENxxxxx\ROTTENxxxxx.FLAC
                • exec
                  • Dec 2007
                  • 53
                  OK, I've tried it with [infile_long] and [outfile_long]. It's not woking again... :(
                  Now in the debug log it says:
                  Code:
                  Command Line ' -o C:\Users\User\Music\Rotten Sound\Rotten Sound - Veenom.flac.tmp.flac C:\Users\User\Music\Rotten Sound\Rotten Sound - Veenom.flac.tmp.flac.tmp.wav'
                  Why there is this "*.flac.tmp.flac" and "*.flac.tmp.flac.tmp.wav"?
                    • 45180
                    You would need to close in quotes, ie "[infile_long]"
                    • exec
                      • Dec 2007
                      • 53
                      Sorry for pushing that topic so far... :o
                      The qoutes doens't matter, still not working.
                      I just wonder, because there is no such problem using lame.exe/CLI - there it's working since the first try. Maybe flac.exe/CLI is just incompatible?
