CD Ripper won't work over Remote Desktop
  • wheelson
    • May 2011
    Re: CD Ripper won't work over Remote Desktop
    I ran into this problem as well and simply right clicking on dBpoweramp and selecting "Run as administrator" solved this problem as well. For me anyway.
    • GarageMahal
      • Feb 2004
      Thanks much!
      I am copying the directions here in case the linked page goes away:
      Start Group Policy Editor
      Go to the Start menu and type in: gpedit.msc
      In the left pane of Group Policy Editor, navigate to Computer Configuration -> Administrative Templates -> System -> Removable Storage Access.
      In the right pane of Group Policy Editor, change the value of the Setting, All Removable Storage: Allow direct access in remote sessions, to Enabled.
      Exit Group Policy Editor and you should be able to burn a DVD over Remote Desktop now
      • dealmein
        • Jan 2012
        I had this same issue. Change the properties of the icon, Under the compatibility tab, check "Run this program as an Administrator"
        • JMinSF
          • Mar 2007
          • 8
          Same problem here. The original directions are long gone, but the equivalent info is on the Microsoft web site at http://windows.microsoft.com/en-us/w...ote-connection. Same approach of modifying the group policy. Running as administrator also works, but is a bit too permissive for my taste.
