discWelder Chrome problem with dbPoweramp converted WAVs
  • pacocap
    • Dec 2009
    I have this weird problem with discWelder Chrome not being able to encode WAVs created with dbPa from FLACs. Ones created with foobar2000 work fine but I get the following errors with dbPa WAVs:
    1st msg:
    resample returned 2
    2nd msg:
    Recorder Error:
    The mirroring operation failed.
    54
    Error resampling "C:\temp\01 - TRACK 1"
    Does anyone know what is causing this problem and how to resolve it?
    Thanks for any help.
    • 43926
    Re: discWelder Chrome problem with dbPoweramp converted WAVs
    Run dbpoweramp configuration >> Codecs >> Advanced
    and disable wave id tagging.
    • pacocap
      • Dec 2009
      Thanks Spoon for your quick reply. I changed 'Wave ID Tagging->Tag Creation' to (none). That didn't work. I then also changed 'Wave Encoder->Write Extensible Header' to 'Never'. Unfortunately that didn't work either.
        • 43926
        The wave file would be a very simple wave file (only header and data), perhaps discwelder does not like spaces in the filename.
        • pacocap
          • Dec 2009
          No unfortunately that's not it because the filename is the same for the foobar2k-generated files.
          • pacocap
            • Dec 2009
            I don't know if this will be helpful but here's a listing of the differences in the two generated WAVs:
            foobar2000:
            Code:
            00000000h: 52 49 46 46 2C E3 EE 01 57 41 56 45             ; RIFF,ãî.WAVE
            dpPoweramp with tagging and extensible header disabled:
            Code:
            00000000h: 52 49 46 46 B4 E5 EE 01 57 41 56 45 62 65 78 74 ; RIFF´åî.WAVEbext
            00000010h: 80 02 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ; €...............
            00000020h: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ; ................
            00000030h: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ; ................
            00000040h: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ; ................
            00000050h: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ; ................
            00000060h: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ; ................
            00000070h: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ; ................
            00000080h: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ; ................
            00000090h: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ; ................
            000000a0h: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ; ................
            000000b0h: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ; ................
            000000c0h: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ; ................
            000000d0h: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ; ................
            000000e0h: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ; ................
            000000f0h: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ; ................
            00000100h: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ; ................
            00000110h: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ; ................
            00000120h: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ; ................
            00000130h: 00 00 00 00 44 31 34 32 30 37 39 35 46 34 46 42 ; ....D1420795F4FB
            00000140h: 34 34 42 44 41 43 34 43 32 45 36 45 31 43 38 44 ; 44BDAC4C2E6E1C8D
            00000150h: 31 45 41 42 32 30 30 39 3A 30 39 3A 30 39 31 32 ; 1EAB2009:09:0912
            00000160h: 3A 33 34 3A 32 37 8C D5 A9 00 00 00 00 00 00 00 ; :34:27ŒÕ©.......
            00000170h: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ; ................
            00000180h: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ; ................
            00000190h: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ; ................
            000001a0h: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ; ................
            000001b0h: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ; ................
            000001c0h: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ; ................
            000001d0h: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ; ................
            000001e0h: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ; ................
            000001f0h: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ; ................
            00000200h: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ; ................
            00000210h: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ; ................
            00000220h: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ; ................
            00000230h: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ; ................
            00000240h: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ; ................
            00000250h: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ; ................
            00000260h: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 41 3D ; ..............A=
            00000270h: 50 43 4D 2C 46 3D 34 34 31 30 30 2C 57 3D 32 34 ; PCM,F=44100,W=24
            00000280h: 2C 4D 3D 73 74 65 72 65 6F 2C 54 3D 53 41 44 69 ; ,M=stereo,T=SADi
            00000290h: 45 35 00 00                                     ; E5..
            These both appear at the beginning of the file so I assume they are both headers. The data that follows is identical for both files.
            • pacocap
              • Dec 2009
              BTW this only occurs when I try to create a mirrored VIDEO_TS. It creates DVD-A files fine but not DVD-V files. When I edit out the extra header data it works for both A and V.
                • 43926
                Use the DSP effect ID Tag Processing and delete all tags when converting (there is a Bext tag being written as a bext specific tag is passed from the source file).
                • pacocap
                  • Dec 2009
                  Bingo! That did it. It is now identical to the fb2k file and it works as well in discWelder. Thanks for your help!
