Audio_Info dissapointing
  • oehlrich
    • Jun 2009
    • 24
    Hello,
    evaluating dBpoweramp I found the Audio_Info plugin hoping it will give me useful info about my hires (24/96) Rips.
    I expected to get iformation if there are really 24 Bit inside the file instead of only 16 used and info if there are frequencies above 22kHz on the track. But I fond neither.
    Did anyone out there know a tool that makes such a kind of quality check of hires files?
    Charly
    • 43936
    Re: Audio_Info dissapointing
    Audio info does not perform analysis on the audio, only what is reported about the audio. It will should 24 bits or not for lossless audio.
